Originally Posted by
logger
There is a theory going around the traps that you can reset a DSG7 gearbox by doing this:
"With the vehicle stopped and engine turned off press the accelerator completely to the floor including the lower stage where you feel the click and hold it for about 10-15 seconds. this will reset the DSG and it will relearn." or in short by activating the kick down switch for >10 seconds with IGN off.
I believe this is rubbish and does nothing. It is myth born out of a requirement in the post DSG reset fast adaption process to drive with different pedal positions. Including momentarily at 100% pedal so that the controller can recognise the value for full acceleration.
I then tested the accelerator trick to see if has any effect. I noted the number of clutch adaptations on DSG7 via VAGCOM and there were in the order of 160 & 170 for each clutch after ~ 5 months. So I then applied this foot to the floor procedure for various time periods over 20 seconds with IGN off and on. I then rechecked the adaptation counts and they remained unchanged. So perhaps I am doing it wrong or more likely it is just a crock.
So I then reset the DSG7 properly using VAGCOM and as expected the clutch adaptation counts dropped to zero. Next step was to attempt to complete the "Test Drive after OAM basic settings" procedure and as expected the clutch adaption counts climbed from 0&0 to 2&1. If the test drive is completed successfully there should be at least 3 per clutch. I was a couple short of the 3 per clutch but clearly the adaptation was under way again again from a reset at 0.
Procedure goes on to say:
"If the test drive cannot be performed in the recommended way for the necessary length, the still open fast adaptations are automatically and unoticeably performed in the subsequent driving cycles."
So to my mind this dispels the foot to the floor reset myth.
