Results 1 to 10 of 11
Thread: DSG will not in basic setting 255/101/0
    Nov 2015
    Amsterdam
    Hello all,
    Sorry for my bad english, but I translated by a translation machine.
    I have a golf 6 1.4 TSI DSG 7 -speed 2009.
    My clutch was worn out so I have put a new plates .
    Just want the car now not in basic setting.
    When I at auto trans basic setting 060 intoets I first get a code 253 then some. I had sought means that the procedure has been started. Then you'll hear something ticking off the mechatronic and comes 255/101/0 code . I looked up and it means kupwegrampe k2 timeout . Maybe someone knows here what the exact content ?
    Trinidad and Tobago
    K2 is clutch two I believe. Don't know much else about this.
    Have you seen these threads?
    Replaced DSG7 gearbox, new one wont start adaptation.
    How to reset/apply Basic Settings for the 7 Speed DSG?
    Nov 2015
    Amsterdam
    Yes, I had read. I 'm going to try to look a little longer to drive than what the car is doing .
    Jul 2011
    Have you correctly installed clutches as per manual with correct shim spacers??
    Nov 2015
    Amsterdam
    Ja ik heb de koppeling geinstalleerd door middel van luk reparatie cd de leverancier van de koppeling.
    Ik heb gister met de auto gereden. De auto schakelt moeilijk over met een dipje na ze 2 versnelling. Wanneer je in de 2e versnelling zit kan je geen gas meer geven.
    Als je de auto in ze R zet wil die niet achteruit rijden. Het lijkt alsof er een handrem opzit. Wanneer je de auto uitschakeld en weer opnieuw start gaat de auto wel in ze achteruit.
    Esp and epc message on the dashboard and de engine light
    Fault code Vcds: P072B
    Jul 2011
    Have you ever removed the mechatronics whilst changing clutches?!
    Trinidad and Tobago
    Translations?
    Jun 2007
    Quote Originally Posted by Rawcpoppa View Post
    Translations?
    Very interesting, one seems to be talking Dutch, the other German! LOL
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Jul 2011
    Google translate lol I tried!!
    Jul 2012
    Sinagra, Western Australia
    Even incorrectly shimmed, basically is it failing in the first stage with engine off or with the engine running(2nd stage).
    Failing in the first step generally indicates a fault with the mechatronics setting the gears. It shouldn't have been touched when doing clutch replacement but did you make sure to cap off the breather so the irreplaceable fluid did not leak out?
    Failing in the second step indicates a fault in the shimming or adjustment of the clutches. Did you use all the tools correctly?
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
