Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: DSG Sports mode issue
    Dec 2009
    Gold Coast, QLD
    DSG Sports mode issue [FIXED]
    Hi All,
    I've had my GTI since december and its been nothing but a pleasure. I'm quite looking forward to a massive audio upgrade in the next couple of weeks.
    However, I seem to be experiencing a gear change issue while the car is in sports mode. The shift up through the gears is perfect but the shifts down (usually 3rd to 2nd) results in the car making a sound similar to hitting a huge pot hole. I have only used sports mode three times and it has done it on all three occasions. I initially thought it was something I was doing wrong, ie braking to hard coming into a corner but I tested it last week on a straight road, and the rough change still occured.
    I know someone else was experiencing a similar problem, I tried searching but was unable to find the thread.
    Anyone have input on this situation, I'm booked in at VW to have it checked on the 8th of june.
    Thanks
    [Update 9/7/10] VW will be replacing the entire transmission
    [Update 16/7/10] Taking the car to vw today for the DSG replacement, lets hope the car gods smile upon me today.
    [Update 18/7/10] PROBLEM FIXED!! Gear changes feel much faster, the car now rev-matches on down shift and is much easier to drive fast. Big thanks to Gold Coast VW for the work
    Feb 2009
    Sydney, Australia
    Yeah - take it to the service centre. It may need the DSG to be reset or the mechatronics unit replaced. Other members have had the issue resolved by one of those two things
    Apr 2010
    Sunnybank Hills, Qld
    I have the same problem with my S mode as well, but due to work and other things, i havent had the chance to get it checked out. But i will be getting it checked out this week, and i will post the results.
    - Azngti
    | GTI | Red | 3 dr|
    If anyone needs a new computer please visit this website http://compulse.yolasite.com/ . Guaranteed cheapest in Brisbane.
    May 2009
    Nothing that sounds as bad but I find mine hangs onto 3rd gear then abruptly jumps into 2nd while in Drive mode. I've had it back to the dealer about how it started to really clunk (to the point where the car would noticeably shudder) into gear from Neutral to Drive and got the usual 'its a manual gear box blah blah' story.
    2010 MKVI GTI DSG - Pearl Black - MDI - Satnav
    Dec 2009
    Gold Coast, QLD
    Update: Dropped my car off at VW Gold Coast, told the service guy the exact problem. Picking it up this afternoon, Hopefully the issue is fixed.
    -Skitz
    Jan 2008
    Quote Originally Posted by Skitz View Post
    -Skitz
    You need to take the foreman out in the car and show them, show them how to replicate it and show them how often it occurs. If you don't do this you're really wasting your time as they will drive differently to you and may not have the problem occur and will dismiss it as a non event or normal operation.
    Dec 2009
    Gold Coast, QLD
    Quote Originally Posted by Maverick View Post
    Yeah, that did cross my mind when I dropped it off. Hopefully they can rectify it first go, if not I'll have to show the foreman like you said.
    -Skitz
    Dec 2009
    Gold Coast, QLD
    Picked up my car 30 minutes ago from the dealer, the service report stated they couldn't find the problem. I took a technician for a test drive and it all seemed fine, the gear changes were smooth through the range and I couldn't replicate the problem. I believe they just re-flashed the ecu or similar.
    The person I took for the test drive stated they had seen 10 or more GTI mk5's with a similar issue and required the mechatronic unit replaced. However he had not seem any Mk6's with this issue.
    Will give it a good run on the weekend and see if the problem is truly gone.
    Apr 2010
    Tys for the update, i havent been able to take mine in still cause it finally got fixed this week. (A car reversed into my gti, had to get front bumper change etc etc. waited 3weeks). But the other day i decided to drive in S mode to see how it is. Suprisingly nothing happened, no odd downshifts from 3rd gear to 2nd. But i didnt slam the breaks, i just drove normally. So i think for my car, it's only occurs if i slam the brakes too hard during 3rd gear that it will cause a really loud noise then downshift to 2nd.
    | GTI | Red | 3 dr|
    Dec 2009
    Gold Coast, QLD
    *Sigh*.....my problem seems to have reappeared.
    Took the GTI for a drive on the weekend and decided to use sports mode. Had 2 very rough downshifting while slowing down for a round about. I was in 3rd gear approaching a roundabout at ~75km started braking and it shifted 3>2 very very rough. Loud sound with jolting in the cabin. Seems like I need to ring VW. Damn it.
