Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: DSG "S" mode is a bit bonkers!
  1. #21
    Apr 2010
    Nedlands, WA
    Quote Originally Posted by ozgti View Post
    Mine changes to 2nd at about 15kph. unless I give it a decent bit of pedal, it's really sluggish. Smooth, but sluggish.
    Mine does about the same. I guess if you're coming from a torque-converter automatic with an initial surge of acceleration when you put your foot down, or drive a manual like my housemate does (flogging it in first on every take-off), the steady/constant acceleration of the DSG would seem sluggish. Whereas in normal driving I've always shifted from first to second pretty much as soon as the car was rolling, so the DSG's behaviour feels natural to me.
    Quote Originally Posted by logger View Post
    Actually no need for DSG reflash, the APR stage I ECU upgrade on my tsi118 seems to change the DSG shift points. Difference is quite noticeable if you go looking for it.
    Ever since I saw your thread on the APR upgrade, I've been trying really hard to convince myself that I don't want one. Sooner or later I suspect I'll succumb...
    Golf 118 TSI DSG, white with sports pack.
  2. #22
    Feb 2009
    Sydney, Australia
    On my first VW I held out for two months before getting the APR ECU... the only regret I had was waiting so long...
    On my seconds VW I picked it up from the dealership at Parramatta, then drove it over to Derek at European Autotech at Mona Vale to get the APR ECU, on my way home to.... The Hills District, lol.
  3. #23
    Jan 2010
    State of Denial
    Yes S mode is a bit bonkers unless you want to hold revs through corners and sprint out of them so I use D for 99% of driving. The only time I normally manually select gears is in underground carparks where 1st gives better speed control going up and down steep ramps. My 7spd DSG had noticeable hesitation off the line when I first picked it up, but with over 5000km of driving its now much better to the point that it is no longer noticeable, I thought it might have been just me getting used to it, but I've had a couple of people drive it since who normally drive autos and when asked about the delay afterwards, they both said they didn't notice (maybe they were being polite).
    It probably just needed a few kays for the clutches to bed in and the transmission to adapt to the bite point on the clutches.
    I do find that it responds better to smooth accelerator tip-in as it appears to have some sort of algorithm running that gives more aggressive shift points and a faster than expected takeoff if the throttle is tipped in rapidly.
  4. #24
    May 2010
    In my experience most cars have a different redline and a fuel cut out point. The FCP is usually further back than redline. This is the case on nearly every sports car I have owned. Its completely safe and engineered that way. It good fun when you get there!
  5. #25
    May 2011
    mosman nsw
    DSG "S" mode auto change
    Another thing I'm struggling with (Golf R)...
    In "S" mode (auto not paddles) the car sometimes holds 1st gear well into the red-line even though I only have the throttle halfway down. Most times it changes at exactly the right time when the torque feels strongest but not always.
    Is there a technique to change up a gear before it hits the red-line, maybe by manipulating the throttle?, and I don't mean by revving it into the red-line?
    Thanks,
    Niall
  6. #26
    Feb 2009
    Sydney, Australia
    As long as you've waited until the car and the gearbox is warm (if you warm the car whilst driving instead of stationary idling, assume the gearbox is also warm when the OIL temp is at 80+ in the R), then yes as you thought, it's all controlled by your foot. S mode is a lot more aggressive than D mode (hence the title of this thread I merged your thread into) and will take more getting used to. Plus, at 60 and 80 km/h speeds, it'll never get into 6th etc. Then it's amusing to put the cruise control on cause it'll change to 6th, and the slightest touch of the accelerator will make it drop to as low as 2nd!
    Anyway... you must've just got your car, so give it some time and you'll get used to it. Go on a nice long drive on some twisties and experiment with the different mods
  7. #27
    Originally Posted by gerhard
    For those who think the occasional foray into redline territory is going to hurt their Golf, think of this - the Sciroccos which run the Nurburgring 24 hour race run at the redline for pretty much 23.9 hours of that time.
    And rebuild their engine afterwards...
    FirstGolfR
    IN GARAGE NOW. GolfR, Pearlescent Black, DSG, Black 19Inch, Leather, Sat Nav, Dynaudio Upgrade, Sunroof, RVC.
  8. #28
    Nov 2009
    Hills District, Sydney, NSW
    Quote Originally Posted by Firstgolfr View Post
    which is common for race engines, I think the point being made is a redline squirt every now and then is not going to do any harm
  9. #29
    Newcastle, NSW
    Quote Originally Posted by SilvrFoxX View Post
    Every car needs an italian valve clean now and again.
    Audi S3. Sold
    Golf R. Sold
    Citroen DS3 Dsport. Sold
    2016 Skoda Octavia RS Wagon.
  10. #30
    Nov 2009
    Quote Originally Posted by Ideo View Post
    Every car needs an italian tune now and again.
    Fixed and correct
