Yes, another DSG thread. I just ordered a Golf 90TSI DSG early this month during the spring sale, and won't pick it up until next month. While waiting, I did some research online on the DSG reliability issues. Here I would like to share my findings here and see whether they match the experience of other owners.
These are the most detailed description of DSG I found:
VW Audi DSG S-tronic FAQ with common DSG problems, the sensor recall, and video reviews
Direct-Shift Gearbox - Wikipedia, the free encyclopedia
And most recent discussion on DSG is "VW China acknowledged issue with DSG..." /forum-replies.cfm?t=1923736
And after read number of threads here, on whirlpool and vwgolf.net.au, I found the reseaon why a DSG broke down is quite mysterious. Some people are totally find after 50kkm while some had horrible experiences within 1 or 2 years of purchase. Since there is no statistical evidence particular on the reliability of DSG, It's really hard to draw any conclusion just based on a very small non-random samples( I am a Stats major......)
However, I am still looking for answers. Up to now, the most convincing explanation to me is that DSG is an automated manual.
A manual is more difficult to drive, not only you need a left foot to control the clutch but you also need to make a lot of decisions to take the right move. A slushbox auto solves these problems with an inefficient torque converter.
Just imagine what if someone drives a manual improperly. What would happen? Probably the clutch splines wear out very soon and then the transmission breakdown. I guess similarly this is why DSGs are so fragile because of improper usage. Of course, I am not blaming the drivers. It is actually the Mechatronics does the shifting. (Manual mode won't help much, since its basically a manual mode for the Mechatronics not for the transmission itself). I guess this is why after all the horrible stories, all VW did is updating the Mechatronics software. The smarter the Mechatronics it is, the less fault shiftings, the less clutch splines wear out, the longer DSG lasts. However, writing a universal software for all the different countries, all the different driving habits is really hard. Therefore, if we drivers can learn how DSG really works, and adapt our driving style to it, the reliability issue would be less severe.
Here are don't I found in different threads, and please correct me if I am wrong. Discussion is warmly welcomed.
1. Don't let the gears shift to often. I would cause overheating and other problems. Use "S" or "M" instead if happens.
2. Minimize the partial clutch engagement time as short as possible.
In the wiki it says, "When the driver releases the foot brake pedal, the k2 clutch pack increases the clamping force, allowing the second gear to take up the drive through an increase of the 'bite point', and therefore transferring the torque from the engine through the transmission to the drive shafts and road wheels — and the vehicle moves forward. Pressing the throttle / accelerator pedal fully engages the clutch and causes an increase of forward vehicle speed. "
I guess consistent partially clutch engagement would cause a lot of damage.
One example is that in a slow traffic, don't just use the break paddle to control the speed, stop and go as a normal auto. I guess during the whole process the clutch is partially engaged.
3. Don't switch to "N" to often, especially in a stop and go traffic. (I am not quite sure about this one.)
4. Shift down gears in a long slow corner. (Not sure either.)
