I'm having a thinking out loud moment. Is it possible that if dsg finds itself caught between gears because it's next change prediction doesn't match a sudden change in throttle response? Could it be it then doesn't allow a gear selection due to high revs and doesn't want to engage a gear with such high revs for self conservation.
I know my thread is a little clumsy and simple but very interested in the subject as my car on order has dsg.
Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
Viagra on 4 wheels !!
"If you can't fix it with a hammer then it must be an electrical problem"
Sometimes, though it has never occurred from a standing start, only low kms, low rpms and when you accelerate out it misses a gear, revs rise, you then back off the accelerator, go again and its fine! For me its like when you miss a gear in a manual.
I had it serviced 2000kms ago, they reset the DSG and its only occurred once since, will keep monitoring it.
WLF127
When you say back off the accelerator, is it a quick lift then straight on the pedal again or do you wait for the revs to die down first. I figure the more I know how to react to it the better. Even better would be that it never happens of course.
Has it occurred more than just the once since your 2k service?
Yes and Yes! The back off is as you described, foot off pedal then back on and it's in gear and drives off fine. Occurred 4 times in total 3 before the 7.5K service and once afterwards, only in the low speed situations.
One other thing I've noticed in my morning mad dash in front of traffic, is that in 'D' mode there is a slight hesitation, enough to make you check your pants and in manual mode the hesitation is almost non existent. So for future mad dashes in front of large trucks on Leach Highway I keep it in manual![]()
WLF127
Hi all has anyone experienced clutch shudder one acceleration, done about 30,000 k's, the local dealer has committed to replacing it, so all good in that area, is it going to be an on going problem, P.S love the car.
which car is it..?
