Lol.... I'm not sure if you literally mean it's already on the floor, and then the click is it literally forcing its way past the "bump stop" (or whatever is there), or whether you are talking about the regular "light resistence" point where it then presses a switch called "the kickdown switch" (as discussed in the owners manual from memory).
The 1st option would be pointless. It's electronic so once you're at 100%, there is nothing more. The 2nd option means that the car will kick down a gear or two once the switch is pressed rather than hold the gear its in (even in "manual mode").
