Page 11 of 120 FirstFirst ... 9101112132161111 ... LastLast
Results 101 to 110 of 1199
Thread: DSG: Problems, Questions, Likes and Dislikes
  1. #101
    Feb 2010
    Lane Cove, NSW
    Quote Originally Posted by AdamD View Post
    Mine doesn't shift into 1st in manual mode until I'm virtually at a standstill. So it's possibly to do with the gearbox's learned parameters for your driving style? If that's a case, a reset of the gearbox memory may resolve the issue.
    Mine's the same so it must be a non GTI thing...
    So far I'm enjoying the DSG and various modes. I had my first axle tramp yesterday when I forgot I was in manual and gave it a bit from the lights. It didn't sound nice either! I probably use D mostly due to the traffic situation where I live but I really like down changing in manual mode. Sports mode is a little bit annoying as it doesn't get out of third until about 70 kph but it's also good when slowing and it down changes.
    Has anyone mentioned that it's possible to flash high beam or operate the wipers when looking to change using paddles...or at least when you're a newbie it is! I did this a couple of times on day one but it hasn't happened since.. The shift paddles probably are a touch small..
    tornado red GTI MkVI, 5dr, DSG, Sat Nav, RVC, MDI.
    Red Honda Fireblade Red Cooper S (SOLD)
  2. #102
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Tux View Post
    In motorsports, there is only 1 correct hand position, and that is 9 & 3. I'm not sure why they teach drivers other hand positions on the road, but any time you are driving spiritedly you must have your hands in 9 & 3. (there are so many reasons why and this isn't the thread for it).
    In any case, if you're hands are in this position, then it would take some talent to knock the other levers, and the size of the paddles is fine. The only time that it becomes an issue is taking a tight left hand turn, since then you have to move your hands...
  3. #103
    Anyone notice that when you are in D mode (or M or S) and stopped at the lights with foot on the brake, there is a slight vibration noise/feel? When I change into N the vibration disappears.
    I don't understand what could be causing this? I thought the clutch is disengaged when you are stopped, the same thing when in N?
  4. #104
    Feb 2010
    Lane Cove, NSW
    Quote Originally Posted by coreying View Post
    I must be quite talented then! It actually is an issue at various times when you are new to driving a vehicle with paddles. As I stated it hasn't been a problem since day one. Also I think you'd find there are plenty of people who believe the paddles are too small as there are after market extensions out there. I think they okay once you get used to them...
  5. #105
    May 2010
    TBH I thought the paddles are a bit small, and that they are awkward to use around corners.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  6. #106
    Feb 2009
    Sydney, Australia
    Yep - but those paddle extensions are for the "only time it becomes and issue" issue
    With the paddle extensions you can then reach the upshift whilst still in that tight left hand turn
  7. #107
    Feb 2009
    NSW
    Quote Originally Posted by hazamatic View Post
    mine does the same. I think it has to do with the clutches.
  8. #108
    Melbourne's East side
    Quote Originally Posted by ozgti View Post
    So has anyone worked out how to stop the Manual mode from shifting to 1st at about 15kph? It's starting to bug the hell out of me. It doesn't do it in D or S mode, so why should it do it in M mode?
    I had also been thinking its probably because you have a 118 and others like myself had the GTi,
    so there probably lies the difference with the 7 sp verses 6sp.
    Also like Adam, little confused with your name too with GTi in it too?
  9. #109
    Feb 2009
    NSW
    Quote Originally Posted by GTI-mk6 View Post
    I have a 1984 mk2 2 door gti I imported from the UK, hence the name. I signed up when I was still over there hence ozgti.
    So noone knows if you can change the programming/shift points of it?
  10. #110
    Feb 2009
    Sydney, Australia
    Only with your right foot...
