So my wife's 2012 90TSI with the 7spd DSG (DQ200), which we don't own anymore but is still within the family, has just had a transmission oil leak and reportedly mechatronics failure. I had the clutch packs replaced under warranty in 2015 and was told during the DQ200 mechatronics recall that our car wasn't affected. So I called the dealer today to say clearly it was and asked them what they / VW Aus could do and they said they'll request a goodwill repair from VW Australia, pending their own diagnostic tests. So hopefully it gets covered at least partially or completely.
Hey guys.
So as the title suggests my dsg is clunking.
I only bought the car last week but got rwc today and mechanic said he was suss on the dsg.
Basically when stopping and selecting reverse it clunks a few times then goes to reverse. And similar when going reverse to drive after reversing..
Could this be a bad gearbox or mechatronic unit I've read about?
Seems to shift on when driving but does get to 6th at about 60km and is a little hesitant at starting off.
Any suggestions on how to diagnose would be most appreciated.
Its a 2010 GTD.
Sent from my G8141 using Tapatalk
Perform a DSG reset via VCDS and see how it goes from there.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Ok will do. Have ordered from Ross tech should arrive Monday.
Very nice. VW seems to be handling this issue alot nicer these days.
hey guys/girls. Have a 2010 GTD, DSG, reasonably sure the mechatronic unit is stuffed.
When changing from park to R / D she is a little clunky and had it flash up D 1 2 3 4 etc the other night.
Have a vcds from ross-tech so did the basic settings reset for the dsg however doesnt seem to have improved it at all.
No errors showing since reset / hasn't flashed up again since.
It felt like it was in neutral / wouldnt engage reverse when the gear indicator was flashing on the dash.
Long story short - best place to have it replaced / confirmed that it is the mech unit?
Am aware the dsg7 has recalls and the dsg6 has 10 year warranty in usa but not here.
Any suggestions would be awesome! Cheers
I've read that my13 and later mk6 had 5 year warranty on dsg. I believe that you need to do a dsg adaption as opposed to a reset.
Sent from my LG-D855 using Tapatalk
MY11 MK6R: Candy White, DSG, Vienna Leather, RNS510+ DynAudio, Sunroof, 19" Black Taladegas, ACC, RVC
