Page 9 of 120 FirstFirst ... 78910111959109 ... LastLast
Results 81 to 90 of 1199
Thread: DSG: Problems, Questions, Likes and Dislikes
  1. #81
    Feb 2009
    Sydney, Australia
    Lol... thanks Maverick. I was thinking more along the lines of an option within the MFD or something which didn't require me pulling the car apart
  2. #82
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by djooz View Post
    .. so with a lil brake pressure, got the revs to bout 2.5k rpm and popped the brake, after a bit of fuss from the TC, she got underway quite nice ( well for me anyway) but for the 1-2 and 2-3 change I got this clunk/vibration (could feel it thru my body), is this the electronic diff lock engaging? it wasn't the most pleasant sound...DSG box btw
    Just checking back in on this djooz. Can confirm my 118tsi will not allow itself to rev above ~1200rpm with the DSG7 in D or S and a foot even lightly on the brake. So yours achieving 2,500 rpm in this state strikes me as odd. unless you are doing it in N and slamming it to D with the revs up which I doubt. But even doing this in mine drops the revs straight back to about 1k.
  3. #83
    Nov 2009
    Quote Originally Posted by logger View Post
    ...unless you are doing it in N and slamming it to D with the revs up which I doubt. But even doing this in mine drops the revs straight back to about 1k.
    You even tried that!? I feel very very sorry for your DSG!
  4. #84
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by AdamD View Post
    Dont worry my DSG is fine. I first did it at much lower revs to ensure it would operate as I expected.
    There is a sole mechanical connection between the selector and Gearbox, being the cable for the parking lock.
    Everything else is electronic and fully computer controlled. Moving the selector from N to D signals the mechatronic unit the driver has commanded D. It is not going to be actioned by the mechatronic unit until the criteria for selection is met. Hence the RPM drop.
  5. #85
    Brisbane Southside
    Right then, Thanks for the reply Logger. So do I have a problem? I'll book it in at the stealership....For the record I'm not going from N to D/S, I'm rough with cars, but not THAT rough. Apart from the fact mine is reving a too high (maybe 2.5 was generous, lets say between 2-2.5) no one else experiences this wonderful sound under hard loud pedal in S mode at the gear changes 1/2 & 2/3?
    Keep in mind I've never owned an auto, let alone a automated manual, so honestly don't know if this clunk is normal, I vaguely remember the test drive car making a similar sound..... Maybe I'm just paranoid, I don't really want to take it back to the dealership, they are a pack of ***** *****
    Thanks
    Djooz
  6. #86
    Aug 2009
    Melbourne, Vic
    I do not know if it is a problem. I would question why you are not seeing the EPC throttling your revs when you are in gear (D or S etc), stationary and have your foot on the brake though. that does not sound right to me unless they have changed things.
  7. #87
    Nov 2009
    Excellent, that's a relief.
    So presumably this also protects the gearbox from those used to automatics, who move the selector from R to D (or vice versa) while the car is still rolling.
  8. #88
    Aug 2009
    Melbourne, Vic
    Yes it does. Works very nicely. Reverse a bit, then while still moving backwards, lightly press brake pedal, it will allow you to select D and it will keep rolling backward depending on slope. Then press accelerator, clutch will engage and you will drive of forward. Much like in a manual really.
  9. #89
    Brisbane Southside
    Cheers, Thanks Logger. Whats the best way to reset ecu etc on these golfs, the usual battery disconnect and leave it for an hour or so? Will this get my car back to a factory default? Sorry to sound stupid, but im a nerd for a living so the factory reset sounds most logical to me, if it can be done.
    Don't flame me, my other car is a 94 Nissan Patrol thats mechanical everything....
    djooz
  10. #90
    Manly - Sydney
    What should it rev to on launch control logger?
    Stoney!
    6 Sp Manual 118 TSi
    Colour: United Grey
    Build Date: August 09 Delivery Date: 16th Oct 09
    ODO at last fill: 2555km
    Avg Fuel Cons at last fill: 8.6
