Has anyone had the following with their GTI DSG
The following is happening more and more.
The story beings....
Over the last 2-3 months I have found that when I change gears under load (4k-5.5k rpms) I would get the fart noise some times. The other times it is like a full auto were the revs drop slowly and there is no fart noise.
I found that this mostly happens when the engine has warmed up or have gone for a highway drive or if I do a left hand turn and I am in 2nd gear and then when coming out of the corner and giving it some it does the full auto sound no fart noise change even though I am in manual and I change gears via the paddle\gear shift.
I first thought it is time to service the forge DV I have installed, I received a service kit from Forge and went ahead and change springs and cap and re-greased and put it back together.
Found that it was still showing the same symptoms. (DV Services was done 5 weeks ago)
E.g. Last night driving home along the high way I was able to get fart noise when I was over taking people and changing gears. But then suddenly with no warning when I went over take again there was no fart noise but just the auto sounds when changing, even though I was up in the 4k rpms and in 4th gear.
The following mods
Apr Stage 1+
Apr exhaust
Forge DV.
Carbonio CAI
Any thoughts on this issue would be great or if people have had the similar issue and they found a solution would be good as well.
Tom
06 GTI MK5 Tornado Red, APR Tuned; ,
09 Tiguan TDI MY10, Black, Fog Lights, Tint, MDI, Bi-Xenon, Dynoaudio, Parking Assist, Rubber matts.
