Don't the TSI model comes with steering wheel paddle shifter? or is that just on the GTI?
I see...
previously I had a V35 Skyline with 5sp AT-X that has a tiptronic mode. so for me crossing over to my GTI's DSG is not a big deal as I have gotten used to shifting up by pushing forward and pulling back to shift down... I did have a few ga ga in the V35 in the first few weeks where instead of shifting up I shifted down but after a while it just get used to it...
Golf GTI MY11 Mk6 Reflex Silver 18inch MDI RSC BT Dark Tint G|Techniq - Buya!
Been reading this thread and others for a while now, and I've been driving my wife's Jetta TFSI for the last two weeks. My only complaint of the DSG is the backwards up/down of the manual control on the stick. Yes there is hesitation, clunks and weird changes but most importantly it still has gear changes that are 99% of time better than I can do in my manual. Whilst I have more fun using a manual gearbox on the right bit of road for most of my driving which is around the city the manual gearbox is a PITA, DSG is so much easier. So I am anxiously awaiting the arrival of my R so I can enjoy the DSG properly with the paddles
Thanks for the good reading guys![]()
WLF127
Interesting that some of us perceive this to be the wrong way around, whereas others (including myself) find it perfectly intuitive. Very much a matter of preference it seems. If it helps, when moving the lever forward it is rotating upwards fractionally and when moving aft, downwards ever so slightly, in the same sense as the gear selection.
Its a bit like the European indicator placement on the left instead of the right of the wheel. There is probably no "correct" configuration. We can fairly readily adapt to how it is. Provided we are not routinely switching types of car.
On the other hand if you configured the steering wheel so you rotated the bottom arc in the direction of desired turn (more like a tiller), the consequences would be catostrophic
Anyway the paddles would be wasted on me, because I find the gear selector tiptronic just fine.
IFYPFY devil's-advocate-stylefor most of my driving which is around the city the manual gearbox is much more involving, DSG is so dull![]()
The biggest thing that bugs me about it (more than the direction of the tiptronic selector, which I think is backwards) is that there's a delay of about a second between pushing the gear stick forwards and the DSG actually selecting the next gear, unless you're quite close to the redline. That makes it almost unusable for me in ordinary driving. Fortunately, "D" mode is very very good.
Golf 118 TSI DSG, white with sports pack.
Yeah I think that is a fair criticism, there being a slight delay in tiptronic changes when going easy on the revs. At least there is with the DSG7. OTOH I tend to be driving in a more sporty manner and higher revs when using T so I do not really set the delay.
Sent from my Nexus One
logger, as far as I'm aware, all sequential gearboxes in race cars are push forward to shift down, pull back to shift up. This also matches the forces of gravity on your actions at the time, and also matches flight yokes, motorbike gearboxes, etc etc.
The shifter for the DSG is the opposite to all these, hence, completely unnatural to me, and the reason I've done things like start the S2TPP DSG Paddle Shift group buy to avoid using the shifter at all costs.
The 'Daytona' type games at Timezone when I was a kid, and the Selespeed in my Alfa 156 from about 8 years ago were both the same way round as the DSG, so it seems correct to me!
2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
