Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 101
Thread: DRL / Daytime Running Lights / Driving Lights
  1. #21
    Nov 2009
    North Shore, Sydney, NSW
    I must get my eyes checked if what I just read is for real. Someone want's to turn 'OFF' a safety feature because they believe it doesn't look any good.......... Absolutely
  2. #22
    Jan 2010
    Brisbane - QLD
    Quote Originally Posted by Lima View Post
    This is why it wouldn't be a bad idea to make DRLs mandatory. Or getting a licence in this country could be aligned with the responsibility of driving on the road rather than giving them out with Cornflake packets.
    Of course it will be easier and more electorate friendly to introduce DRLs, haha.
    The amount of ignoramuses driving at dusk, during fog and other inclement weather without using lights is astounding really. If such people cannot make a simple judgement call at these times then one can only wonder at what other poor habits they have.
    Well, I think you have me convinced that I should leave them on, just to remind other morons that they should have lights on also. I still believe that I can make a decision on whether or not to turn my lights on if road conditions should dictate that, and I'll always be first to do so. I'm just anti dictatorship with how I should drive my car, whether it be lights, wipers or whatever. Soon the world government will tell me that I have to drive in economy mode all the time and you wont be able to change it on your car, just like DDL. Beware, the climate change protagonists will rule your life.
    Brian
    Current drive:2016 Golf GTI 40 Years in Pure White
  3. #23
    Nov 2006
    Canberra, Australia
    Haha, good on you Brian.
    Good to see you have a white car too, which helps!
    We usually leave the lights in Auto on our cars, which means LED DRLs for the S3 and just lights on when need be in the GTI. Although, in overcast conditions we'll usually err on the side of having the lights on too early.
    I became much more aware of such issues when we had our Mk4 GTI which was black. Generally speaking I ran the low beams all the time as I noticed that other dark cars could be difficult to see during the day when driving through tree lined streets etc.
    I also used to drive quite a lot of highway kms not long after I started driving and quickly saw the benefits of having lights on during the day.
    MY10 S3 3dr
  4. #24
    Sep 2009
    Quakers Hill, NSW
    The rest of the world is catching up with 1980's Volvos.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
  5. #25
    Firstly, are DRL's standard on the 118tsi?? Because it would appear that mine doesnt have them and based on what ppl have said in this thread, i get the impression that they are....
    Quote Originally Posted by sillygogo View Post
    DRLs are designed for safety, you can turn them off if you wish. For the TSI.
    From memory: turn the light to the OFF position, pull back flasher + LEFT indicator at the same time + start engine, Turn off engine.
    To turn back on DRL same as above but RIGHT indicator instead of LEFT.
    Seeing as mine aren't on (if i even have them), i tried your method a few times to turn them on but it didn't work.
    MK6 Golf 118TSI |DSG|Reflex Silver
  6. #26
    Albion QLD
    Quote Originally Posted by kimiraikkonen1a View Post
    DRL's are standard on all Mk6 Golfs.
    I've noticed that on some of the loan cars I get however, they don't have them on. I think it's got something to do with the comfort settings?
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
  7. #27
    Nov 2006
    Canberra, Australia
    Quote Originally Posted by cme2c View Post
    Except new/current Volvos don't have DRLs any more. Which I always found odd given you rightly point out they are well known for them.
    MY10 S3 3dr
  8. #28
    Quote Originally Posted by maca View Post
    So what you're saying is that I should have them and that i should call up my VW dealer and demand they activate them?
    Are they a separate bulb to the park lights? because i had a look at the all the bulbs and I can only see the high beams and the parkers in that refletor fixture.
  9. #29
    Albion QLD
    Demanding them to activate your DRL's will get sugar in your fuel tank next time you take your car in for a service. I'm guessing you've gone through and read the instruction book yeah? I've played with a few Mk6's before and I've found that if you reset the comfort settings (I think it was these), they come on.
    The DRL's use the same bulb as the high beam, similar to how some cars use the same bulb for main/high beam. The reflectors are set up so that it won't dazzle oncoming traffic.
  10. #30
    Dec 2009
    Kew, VIC
    My TDI had the DRL's on as delivered — since it's a white car it stands out well enough and I see where I'm going perfectly well in daylight, I turned them off. The somewhat arcane procedure is in the manual, as is how to re-enable them.
    Since it runs headlamp bulbs, which are tedious things to replace in the Mk 6 and it must shorten their useful life, I'll leave mine off unless/until I'm forced to turn them on again.
    In over 65 years of driving many different varieties of transport I've never needed many of the so-called essentials of today (although I have to admit I'm impressed with electronic stability control — if I'd had that in some of the devices I used to race...)
