Results 1 to 3 of 3
Thread: Door Trim Removal
    Nov 2009
    Door Trim Removal
    I'm thinking of installing some Dynamat in the front doors of my Golf GTI to improve bass performance and reduce road noise (thanks for the tip TDiJetta09!).
    But before I do, I was wondering if anyone knows of the proper procedure for removing the door trims? Eg the location of clips and the order in which they should be removed (and subsequently replaced when refitting the trims)? The last thing I want to do is break clips and add rattles!
    Thanks!
    Apr 2009
    Not sure on the procedure Adam. Google didn't turn up much. But I would recommend getting a set of these from Jaycar before you do.
    Car Panel Removing Tools - Jaycar Electronics
    I used them to remove the Roof console and A pillar trim and RNS510 surround. They are great.
    Aha!! Found a link for you.
    http://golfmk6.com/forums/showthread.php?t=5095
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
    Nov 2009
    Thanks Ozram - great link, much appreciated!
