Results 1 to 7 of 7
Thread: Door hinge loose
    Feb 2009
    NSW
    Door hinge loose
    Anyone else had a loose door hinge? Mine clunks a few too many times when opening and closing.
    Nov 2009
    Is it actually loose (do you feel flex if - gently! - applying upward force at the unhinged end of the door), or does it just require lubrication? There's a fair bit of grease on the hinges; that may wear away with time, washing, etc etc.
    Feb 2009
    NSW
    Nope, just checked again, I can actually see the hinge moving on the door.
    Jan 2011
    Quote Originally Posted by ozgti View Post
    Back to the dealer for adjustment I think...
    - Golf 7 R DSG White -
    Jul 2010
    Qld
    My driver's door lower hinge looked like it wasn't tightened properly at the factory. They were only finger tight. It took about 10,000km/6 months to become apparent. Since being tightened by the dealer it seems an annoying whistle that was worst in wet weather.
    JFTR, car is a 2-door, built in July 2010.
    If you dig a hole and it is in the wrong place, digging it deeper isn't going to help.
    Sep 2010
    yes, my driver's door hinge came loose in the last few days. a couple of the bolts were completely loose
    took it back to the dealer this morning "...that's unusual..." they said. "Have you had any panel work done on your car ?"
    No, it is a 14month old GTI that's done 18000kms
    Dec 2008
    Sydney/Canberra
    Age and distance are irrelevent in the grand scheme of things.
    Did they take care of it for you?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
