Before paying your flat fee to use erwin, make sure you have the software installed is specified in Step 1 of the Step by Step instructions. Otherwise you won't be able to view the training material.
Thanks again prise.
I signed up for erWin, but haven't used it yet..
I pulled the dash sunlight sensor out this arvo. Neat piece of technology it is too! I'm trying a foil mask inside the plastic cover to see what happens.
Will post the results.
For me, the most noticeable effect was when driving from an shaded (underground) carpark out into the sunshine - the aircon would blast cold air in response to the increase sunlight. Lets see what happens now...
Cheers,
Cam.
MkVI GTI, Tornado Red, Leather, Tint, 17" wheels, Black Euro plates.
Nice sunny Sydney day today and I can report that with a piece of foil inside the sensor it is much better. The fan speed control is much slower in response to sudden temp and light changes. It was noticeably more pleasant driving my GTI today with the aircon controlling off the temp sensor in the centre console rather than responding to the dash sensor.
I think it could probably do with a slightly more responsive sunlight temp sensor when the outside temps are around the 30 degree mark. Will try putting a small hole in the centre of my foil patch to see how it goes.
Cam.
It is an infrared sensor (actually 2 of them) and the plastic cover is a dark clear red - as you would expect.
I tried folding the corners on my foil mask (which sits above the infrared sensors, inside the cover) so it's pretty much a regular hexagon in shape. It stops sunlight directly on the sensors, but allows light to spill around the sides. Some of the responsiveness of the aircon returned, but it isn't overcontrolling. Seems pretty good now.
Also, if you put foil inside the cover like I did, you need to insulate the terminal pins on the top of the sensor circuit board. You'll see what I mean if you pull the cover off the sensor assembly.
The temperatures I logged from the climatronic system are plotted here. The cabin temperature is regulated fairly well, but you can see how significantly the vent temperatures vary - a good reason not to have them pointed at your face!
http://dl.dropbox.com/u/14542234/LOG...11-581-601.pdf
