Page 13 of 21 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 202
Thread: Do you have rattles in the car?
  1. #121
    Jul 2010
    is this still the case with mk6, or have they gone to mexico to make all the mk6 golfs?
  2. #122
    Jan 2008
    Quote Originally Posted by rs73 View Post
    Mk6 Golfs are all made in Germany with the exception of the wagon which are made in Mexico.
  3. #123
    Jul 2010
    Yaaay! had a whole day without rattles! Could be coz the temp was a warm (by Canberra spring standards) 18C yesterday!
    Thought I'd celebrate....until evening came, the temp went down, and the buzzes/rattles were back
    I've tried many times to reduce the buzzing/rattling on the dash diffuser vent, following guides on various sites. Reduced, but still can't eliminate it.
    Passenger seat also rattles in sympathy with road surface, as does the sunroof when tilted open
    Passenger door area also buzzes on some road surfaces
    all this in a car that's only done 23,000km.....
  4. #124
    Dec 2009
    Oz
    Hi guys i know this might be off topic, but thought id share it.
    Just picked up my mk6 Gti today and have noticed i get this rattle/vibration sound in the car, is this a normal thing for the mk6 gti?
    The vibration can be felt thru the clutch when starting from gear 1 but once car is in motion do not hear it anymore.
    At first i thought the sound was coming on because i had the A/C on, but i turned the A/C off and the sound/vibration is still there.
    It kind of sounds like a clutch buzz or something.
    Could anyone share some info on this?
    Ive searched the forum but cant see to find out what this might be.
    Might have to go to the dealer and get this checked up.
    Cheers.
    Formally known as mk6tsi
  5. #125
    Mar 2010
    Witness Protection
    Quote Originally Posted by mk6tsi View Post
    I had a similar rattle/squeek, in 1st gear only when taking off. Turned out to be the lumbar support.
    I also thought I had the annoying door rattle, it sounded like it was coming from the passenger's door. I found out today that it was actually my sunnies rattling around in the sunglass holder.
  6. #126
    Dec 2009
    Oz
    Quote Originally Posted by hooba View Post
    So is it a normal thing on a manual gti mk6 for the vibrations throughout the clutch when starting off in gear 1?
    Can anyone clarify this?
    Anyone else having this problem.
  7. #127
    Mar 2010
    Witness Protection
    It's not normal, and you should be seeing your dealer about it.
  8. #128
    Dec 2009
    Sydney NSW
    + 1, no vibrations through the clutch.
    mk VI GTI, manual, reflex silver, basic
  9. #129
    Apr 2010
    I think my rattle comes from the inside front-left door handle (i.e. the bit you pull to close the door). The one on my side is rock solid, but I get a lil movement and noise on the passenger one if I wriggle it. I'm guessing the bumps in the road cause the noise. It's still easily heard with the radio on.
  10. #130
    Mar 2010
    Someone somewhere on here mentioned a ticking sound from the B-Pillar trim.
    THANKS A LOT!
    I did not hear it until I read your post
    VW should give owners a lifetime supply of earplugs.
    I know the old turn up the stereo to drown them out but that cuases even more
    Even though mine is a MK5 I have:
    Constant rattle in passenger door
    Rattle under heavy bass in drivers door
    Ticking B-pillar/s (not going to listen to passenger side)
    Rattle from roof when sun visor is unclipped (this is a strange one)
    Creaky door seals (krytox lube when I have time)
    The car is only 13500km old!
    Should keep the service department occupied for a while.
    08 Golf GTI - SOLD
