Page 8 of 21 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 202
Thread: Do you have rattles in the car?
  1. #71
    Apr 2010
    Melbourne, Victoria
    Cool thanks Orient Express... I'll give it a go to see if it helps.
    Mk6 Golf GTI, Deep Black, Sunroof, 18" Detroit, Leather, Factory MDI, Xenon, ACC, Tint, Bluetooth.
  2. #72
    Mar 2010
    I seemed to have some slight rattles on 2 of my door trims. They are apparent when I play some base heavy music through the speakers. I suspect that they are from the dealer taking them off to put on my tint, and not securing them back on properly. Would it be reasonable for me to go back and expect them to fix it?
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  3. #73
    May 2010
    I would. Although I've given up on the whole rattle situation. I've used felt tape on every single thing that I could...fixed up one area at a time, and drove it...rear seat latches, glovebox, under the passenger seat...rattles still there, but only over rougher roads (Pittwater Road around Dee Why for all fellow Sydney Siders). I can't get rid of it.
    Oddly, the rattles don't happen when someone is sitting in the passenger seat...at least they are not as bad...so seems as though it's something around the seat area, maybe even belt buckle area, as I've read this is a troublesome area, but I have tried buckling it across the seat...still rattles.
    Apart from removing the passenger seat and dismantling the door (which I won't do), I'm giving up. VW and rattles are a fact of life.
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
  4. #74
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    I was always under the impression one of the reasons the Mk6 was introduced early
    was to rectify the rattle problem.
    A few days back while having my Mk5 serviced two customers in front both their for
    rattle fixes.
    Im now having secound thoughts of trading mine in as its now coming to 3 years old
    with not one rattle and have never had a warranty issue.
    But I do want the new GTD.
  5. #75
    Jan 2010
    State of Denial
    I would rate my 118 TSI as inferior to both Mazdas I've owned previously in terms of rattles and buzzing from the interior trim. There just isn't the same care taken in how they've designed and assembled the interior to eliminate noise sources. There are too many plastic components in light contact with each other that can produce noise over rough road surfaces. The attention to detail in other areas is impressive so it's annoying that they appear to have skimped in this area.
  6. #76
    Jul 2009
    Homebush Bay, NSW
    Quote Originally Posted by MkVIGTI View Post
    I have a rattle coming from the driver's door and thought it was from when dealers did the blue tooth or tint. I have traced the rattle to the little red plastic "light" like thing in the lower part of the driver's door. It only occurs when I drive on rough roads at speed, taken back to the dealer who did "something" but of course didn't fix it, taking it back again soon. I wonder if you have the same problem.
  7. #77
    Nov 2009
    SEQLD
    My car has rattled the day I drove it off the show room floor! Not very impressed! Head unit Surround squeaked, has been fixed. Trim insert on passenger side dash rattled, sort of been fixed and now they are saying the passenger air vent is the rattle which is on order. Car developed a noise coming from passenger side B pillar which occurs on speed bumps, going around corners, slightly rough roads. Getting look at next week. And last of all both front doors rattle when the stereo is turned up which make the system sound like crap! Not letting dealer touch my door since i have the Dyn speakers so I have it booked in at my local VW specialist and paying him to fix the rattles and put Dynamat in the doors. Should sound heaps better then! Other than the rattles the car is great!
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  8. #78
    May 2010
    Quote Originally Posted by TDiJetta09 View Post
    wow, I think we have identical cars in the squeak department!! you wanna trade?
  9. #79
    Nov 2009
    SEQLD
    Quote Originally Posted by ktrianta View Post
    I'm up for a trade since yours is a GTI! I'll even drive it down for you. So you have similar rattles? Has dealer managed to fix them? At least we can crank the Dyn's up, but I still have rattles then Can't win.
    MY20 Golf GTI TCR
  10. #80
    May 2010
    has fixed one, but I've only brought it in once...since then, I now have a:
    1. Loose passenger air vent
    2. Loose wiring harness under the passenger seat
    3. Loose something somewhere
    4. Quite possibly a few loose screws in my head now as well
    5. B pillar trim on rear passenger door (already had the driver's side door fixed)
    6. I now also have a drippy rear washer jet
    I also have a very annoying bat roosting in a tree right outside my bedroom window, screeching all night long. Can VW help me with that?
