Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 202
Thread: Do you have rattles in the car?
    Jun 2009
    Canberra
    The rattle really really drives me nuts. I got a rattle from behind of steering wheel and it is annoying. I have taken the car to the dealer 3 times, every time they promised rattle was gone, but it came back.
    Dude, I don't know if I should take the car to the dealer again or try another dealer. I know this is not the problem only with mk6, but with all VW. Someone says that rattle is the music of VW. If so, this is my last VW car......
    Do you guys have rattles in the car? Do you want to fix them or just live with them and turn music up?
    Platin Grey Skoda Octavia Scout Premium
    Jul 2009
    Newcastle, NSW
    Rattles hmmmm....
    The scourge of the modern car i rekon. And im sure dealers agree.
    I have a Subaru liberty and after 45k kms the only rattle i can find is one right down the front of the windscreen where the dash vent s are, and even then only when its cold weather. It comes down to build quality and materials used etc and i guess thats one of the reasons i bought Subaru. I guess thats also why ppl buy VW. Also, I think theres rattles then theres rattles. I think to a point theyre unavoidable for the small ones, turn the music up, for those really persistent ones, like where you think something is completely loose persue your dealer/s.
    Something i found useful with a previous car (a Misters#itti aka Bitsamissing Verada) which had terrible, Australian build quality was some Selly's silicone spray along the joins...this works for those places that it appears to be two tight joins rubbing together hence causing the 'rattle'.
    On a side, i've owned two early 80's model Mercedes and after the best part of 30 years, 380k kms and 250k kms 'respectivley i couldnt fault the interior for a noise...they were great.
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    I thought one of the reasons the mk6 was brought forward was to rectify the mk5 rattle problem.
    Jun 2009
    somewhere
    Havent got any rattles here at the steering wheel. Only time i get rattle near there is cos I've got too many things attached to my car keys.
    Actually my car is relatively rattle free, havent noticed anything too annoying (Except the CHIRRP from the engine, this is starting to get annoying!!).
    Getting internal wiring in the roof replaced due to interior lights not working...they have to dismantle the roof...(i hope rattles do not develop due to this!)
    Volkswagen Golf MK7 R Wagon Wolfsburg Edition Lapiz Blue
    Dec 2008
    Sydney/Canberra
    C'mon guys, this car was touted as the quietest Golf ever.
    In regards to the rattle behind the steering wheel, have you tried demonstrating the noise to the dealer? Noises can travel a long way in a car. I know I've chased a rattle in the left rear corner of the car, only for it to stop when the E-Tag fell off...
    Also worth noting, the mirror glass in the driver's sunvisor can sometimes vibrate, and can often sound as though it's coming from the dash.
    Jun 2009
    Toowoomba, QLD
    I've got what I bet is the exact same rattle in my MY09 Passat. The dealer said it was my key on the keyring jingling(a load of rubbish as I've held the keys while it was happening when I was 1st trying to source the rattle), I didn't feel like arguing at the time as I'd already been back trying to get them to get the wheel alignment right...
    The rattle doesn't happen all the time but if I press hard around the right side of the dash between the instrument cluster and right air vent, it will stop it -for a while.
    If you do work out what it is be sure to share what it was please.
    Jul 2009
    Newcastle, NSW
    Chief,
    Are you sure its the wiring Ours had the same issue and it was some sort of control module up under the dash, once replaced it was all good. Incidentally it also controls the auto wipers apparently so if lights are out then your wipers shouldnt either on auto setting. Check it out...i wouldnt be keen to have my roof lining removed only for them to find it was something more simple.
    Quote Originally Posted by Schnapp View Post
    Jun 2009
    Canberra
    Quote Originally Posted by okisub View Post
    From last repair report, it said plastic rivet loose (steering column). They retensioned trim and insulated. However, the rattle is still there when the car is on the rough road.
    What I found interesting is if I use my finger to push the plastic trim behind steering wheel, the noise is significantly lighter.
    Im not sure if I should take the car to the dealer again or not......
    Jun 2009
    somewhere
    Quote Originally Posted by Nick View Post
    Chief,
    Thanks mate,
    They assured me it was the wiring. As the interior lights in the front still worked. The backseat interior lights and sunvisor lights did not work. My auto wipers are working.
    Yes, im not very keen on having the roof lining removed...but fingerscrossed no further complications arises as a result of this.
    Jul 2009
    Quote Originally Posted by ox518 View Post
    Funny... i have the same thing. If I touch the trim behind the steering, problem goes. I also have another rattle coming from the centre air vent (or so it seems... hard to tell as sound tends to bounce around the cabin).
    Having said that, the rattle issues aren't really that bad because it depends on the weather / temp. So the result is they're not persistently present in my car.
    In winter, when the car has heated up the squeaks disappear. Now in spring when the aircon runs in the warmer days, I get more persistent squeaks after the aircon has been running for a while.
    In Summer, I'm sure even with the aircon running, the expansion of the plastic (despite the aircon running), will mean fewer squeaks owing to the greater latent heat in the plastic.
    In summary, I think the squeaks will be seasonal & a bit hard for VW to fix (maybe take your car to VW in the morning when it's cooler & plastics have contracted with aircon on full blast to ensure it replicates)
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
