Originally Posted by
ox518
From last repair report, it said plastic rivet loose (steering column). They retensioned trim and insulated. However, the rattle is still there when the car is on the rough road.
What I found interesting is if I use my finger to push the plastic trim behind steering wheel, the noise is significantly lighter.
Im not sure if I should take the car to the dealer again or not......
Funny... i have the same thing. If I touch the trim behind the steering, problem goes. I also have another rattle coming from the centre air vent (or so it seems... hard to tell as sound tends to bounce around the cabin).
Having said that, the rattle issues aren't really that bad because it depends on the weather / temp. So the result is they're not persistently present in my car.
In winter, when the car has heated up the squeaks disappear. Now in spring when the aircon runs in the warmer days, I get more persistent squeaks after the aircon has been running for a while.
In Summer, I'm sure even with the aircon running, the expansion of the plastic (despite the aircon running), will mean fewer squeaks owing to the greater latent heat in the plastic.
In summary, I think the squeaks will be seasonal & a bit hard for VW to fix (maybe take your car to VW in the morning when it's cooler & plastics have contracted with aircon on full blast to ensure it replicates)
Skoda Octavia Mk3
(sold) Golf Mark 6 Comfortline 118
(sold) Golf Mark5 Comfortline Manual 2.0 FSI
