Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 177
Thread: Do you actually use the DSG, or is it always in automatic mode?
  1. #151
    Nov 2010
    Burpengary, Queensland
    Another way to drive a DSG at highway speed (or even as low as 80K), select "S" and set cruise. It will change up to 6 (not sure about 7 speeders) and happily cruise until you apply light pressure to the gas and it eagerly kicks back a couple of gears for overtaking.
  2. #152
    Apr 2010
    Yep, the only way to get into S7 is to enable cruise control. Jumps down to 4th at Fwy speeds.
  3. #153
    Jul 2011
    AU
    The DSG does take some getting used to, to drive it smoothly (especially if you're used to a manual, or a traditional slush box auto), but once you do it's great. As someone before me has said very well, it's a jack of all trades, master of none. For the majority of us who use our GTI or R as a daily driver, the small "compromise" of not having full manual control is almost irrelevant. Once you learn the throttle control required to drive the DSG smoothly, it's great. I do about 2500km a month, most of it spent around the city, some of it on the highway and a tiny bit of it on the race track, so the flexibility for me is a huge feature.
    I used to say I would never buy an auto in a performance car, until I first test drove the MK6 GTI DSG at it's release in 2009. I wanted one ever since - and eventually got one! That being said, I still would not buy a CVT or torque converter auto vehicle. But give me a double-clutch automated manual any day!
    Of course, I am still partial to simple cars with a basic chassis and a manual gearbox, so if I ever get enough garage space for a weekend toy, that's probably what it will be.
  4. #154
    Apr 2010
    Looks like Clutch #2 is slipping (revs go up and down when requesting power in even numbered gears). Is that just a clutch pack I need replacing?
  5. #155
    Apr 2012
    Queensland
    My wife will allways drive it in Auto form , but when i get a chance it will mostly be as close to a manual experience as possible .
  6. #156
    I put the stick in manual when I'm having a bit of a hoon, but that's not often as it's not my primary hoonmobile. I use temporary manual mode when I'm looking to merge or change lanes, just to get it in the best gear before I make a move. Other than at the track, full manual mode is most valuable when I need to make a tricky right turn across traffic, the standard auto map likes to shift out of first quite early even at WOT (unless you go so hard you light it up), which is not ideal.
    I find driving normally in full manual mode just feels a bit weird, almost pointless. The auto mapping is pretty good and generally does what I want it to do most of the time.
  7. #157
    Aug 2009
    Melbourne, Vic
    "Just a clutch pack" sounds like it would be a 5 min job to slide a new one in. I reckon you'd be better to reset the adaptations of the clutch first. Chances are that'll fix it. Sounds to me like the electronic leg that presses your clutch pedal needs a reboot that's all.
    ---------- Post added at 08:40 AM ---------- Previous post was at 08:38 AM ----------
    Cruising on Highway I leave mine it D. But when I go off piste I use the manual mode & S quite a bit.
  8. #158
    Quote Originally Posted by logger View Post
    Electronic leg LOL
  9. #159
    Apr 2010
    Cheers logger (long time no see).
    I assume you're referring to the steps in this thread - have you done this yourself before?
    http://www.vwwatercooled.org.au/foru...tml#post749686
  10. #160
    Apr 2012
    Queensland
    Guys whats the difference between a wet DSG and a Dry DSG and between the 6 speed DSG USED in the Golf GTI and the 7 speed DSG used in the Polo GTI.
    Thanks in advance
    Michael
