Results 1 to 2 of 2
Thread: Difference in ride height between MK6 Golf GTI and MK6 Golf R?
    Oct 2015
    Is the a difference in the ride height between a MK6 Gti and a MK6 R? I am looking at getting the stock suspension from either of these from a wreck or from somebody who has replaced theirs with coil overs. Otherwise I will have to settle for king springs as I dont want the ride height too low. The main question I want answered is the difference in stock ride height between the two cars cheers.
    Dec 2006
    Kilsyth, VIC
    From memory the GTI 's are about 15mm lower than the normal Golf the the R drops this a further 5mm to 20mm lower than your standard Golf (neglecting the fancy push button (DCC) dampening controls in some models). From memory the spring rate in the R is also a little stiffer (20%?). (or am I thinking Mk7?) In any case the drop off stock is less than an inch and even then if you have the "Sports Pack" you should already have that...
    What are you planning on installing these into?
