Originally Posted by
The_Hawk
The stock camera is CVBS (four pins) if that helps.
Troubleshooting tips for you:
Make it as easy as possible.
You don't have to actually install a new camera to test it... you can just plug it into the head unit and see if it works.
Ditto for the head unit. You can just plug it in and see what happens.
As for VCDS, if it's already coded you don't need it. Effectively all those does is flick a switch to tell the car a thing is installed.
What you need is someone nearby with a spare camera you could test and a head unit with a PIN code so you could test that too. Without that you're somewhat left guessing... which leads to the next point.
Just look into a RCD330+ (or other Carplay/Android Auto enabled head unit) and a suitable camera and swap them both out. Newer, nicer and more functional.
