Quote Originally Posted by MkVIGTI View Post
You can actually shift the gear lever from N to P when the engine is off actually, don't need to turn the engine back on.
Yes, but the the ignition key cannot be turned enough to release it from the lock until the ignition is turned back on with the transmission put into N or P, and then the key turned all the way off so that it can be removed from the lock.
