Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Delay on take-off (DSG)
    Jan 2010
    Melbourne, Australia
    Hi all,
    Sorry if this is covering an older post... tried to search but didnt see anything conclusive on this.
    We've finally taken delivery of our Golf 118TSI and aside from the 'common problems' most people have faced (leaking rear washer, rattling parcel shelf, rear senors that didnt work consistently) I'm loving this car! Actually prefer driving this more than my other daily driver.
    One thing i noticed was a lag on take off (e.g. at lights or around corners). Is this normal for the DSG? Although it's nothing serious (yet), I can imagine myself trying to turn right quickly and the car taking a 1 sec to respond. I almost need to start pressing the throttle before i actually want to go.
    What do you guys do to compensate / fix this, or is this one of those things I'm going to have to live with? I've only done 250k's so I'm hoping it will improve over k's / time.
    Feb 2009
    Sydney, Australia
    The hesitation of the DSG gearbox on take off is a complaint that gets mentiond in almost every single review of the Golf ever published. Most people don't care however, as the numerous other advantages far outweigh this single disadvantage.
    As team_v mentioned, if you're stationary with your foot on the brake, tapping the accelerator pedal will engage the clutch for the next 2 seconds so that you can have immediate drive away (at least it did on the MKV GTI with 6sp DSG).
    You can also use the handbrake method STV4SYT mentioned.
    Beyond that, as you get more familiar with the car and the gearbox, you will learn to adapt a bit to it, and it will adapt a bit to you - however that delay will never go away.
    Jan 2010
    Thanks Coreying
    I'll experiment with those tips. Does having the shifter in S mode keep 1st gear engaged?
    Jun 2009
    Quote Originally Posted by 'fatboy' View Post
    Thanks Coreying
    I don't think so.
    From memory it just increases the rev limit before the DSG shifts up a gear.
    Feb 2009
    Sydney, Australia
    As team_v said - no.
    Basically, the DSG is two manual gearboxes strapped together, and the reason there is no clutch pedal is that you'd need two of them, which means you'd need 3 feet So it won't keep 1st gear engaged to reduce wear on the clutch etc.
    Jan 2010
    Ahhh.. it all makes sense. Thanks guys, this has been most helpful.
    That aside I love the DSG gearbox. It shifts so quick and smoothly - just keeps it on power with no noticeable drop off. If only the 118 had paddle shifters...
    Feb 2009
    I agree, maybe press it a bit earlier than you normally would for a manual car.
    Apr 2010
    Nedlands, WA
    There is definitely a lag when taking off from a standstill, though it's much less than a second - I'd guess it to be more like a fifth of a second, though haven't tried to measure it at all. It took a while before I felt comfortable pulling out into or across gaps in traffic, but in practice it hasn't been a problem.
    There's much more of a lag from when you're almost but not quite stationary. The impression that I get is that the DSG changes to neutral at some point decelerating below 30 km/h. Even though the gear indicator reads "D2", the engine is at idle revs and you can hear a clicking sound and get about half a second's delay when you press the accelerator, presumably from the DSG changing back into gear.
    I also felt like the DSG got a lot better over the first 100-200km, but I'm not sure whether that was me adjusting or the DSG adjusting itself. Fuel consumption on my first tank of fuel was dreadful, too. Now with 1300km on the clock, it's still quite a bit worse than I was expecting, but much better than my last car: averaging a bit under 8 L/100km from suburban driving in a mix of traffic situations, short and long trips, etc. The trip meter matches exactly what I get from calculating fuel consumption by hand. No rattles or leaking rear washer.
    Golf 118 TSI DSG, white with sports pack.
    Mar 2010
    The great engines and the quick gear shifts more than make up for it! My old car's auto was way more sluggish in its operations so I don't really have a problem with the slight hesitation.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
    Mar 2010
    WA
    I picked up my last night and I definitely felt the lag fabtoy mentioned. I thought my car was faulty and worried. Good to know that it is normal
    Thanks, Coreying and thanks fatboy for asking the question. I will continue to enjoy my new Golf ^_^
    J
    Hello in 2 weeks time... Tiguan 125TSI :: Deep Black :: DSG
    Hello, Golf MK6 :: 118TSI :: Deep Black :: DSG
    Goodbye, 2004 Polo Silver Match
