Results 21 to 30 of 37
Thread: Decarbonisation for GTI Mk6 at 2 year service?
  1. #21
    Camberwell, Vic
    Quote Originally Posted by Mountainman View Post
    Is this the same as the upper engine cleaner that Subaru use as part of every scheduled service? It costs around $17 and comes out of a can.
    Similar although this was because of Subaru's boxer engines and their design rather than anything else. And let's be honest, VW are not the only ones with DI engines and do other people ask for this? It's probably a nice to have if you have money, and not necessary. BIt like cleaning your car every week. Nice to have but car is still going to work - just looks worse after a few years.
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  2. #22
    Erskineville, NSW
    Quote Originally Posted by Bora Sport View Post
    I have no experience with DI engines however I can tell you that my local VW dealer has been trying to sell me this for the last 8 years and I personally think it is a blatant money grab. I pulled the head off my Vento at around 360,000k's
    Your Vento isn't Direct Injection, so you are correct as the fuel is injected before the valve & the solvent properties would help keep it relatively clean.
    DI injects straight into the cylinder, therefore the inlet doesn't get any solvents & depending on driving style, PCV, etc you could get a fairly hefty build-up of carbon on the inlet.
    Something like this:
  3. #23
    Jan 2008
    Sunshine Coast
    Spot on. Explain to me how a spray is going to remove baked on carbon, let alone a mm or two of gunge PCV/egr oily sludge mix.
    Will help, and better than nothing, but you eiother ignore it, physically clean it, or get a catch can of some sort. Even that doesn't totally stop it.....even your turbo is a total oil loss bearing....
  4. #24
    Maitland, NSW
    Since any carbon build up in a DI engine is going to be sourced from oil mist from the PCV or turbo bearing, surely the Very Expensive VW approved oil would be formulated to address this problem?
    If it is an issue with MK6 golfs, I'd want to see some dismantling done for $185.
    MY12 VW Golf 90TSI DSG, MDI, Towbar
  5. #25
    Jan 2009
    Quote Originally Posted by rossw View Post
    That's one of the aims, yes.
    A field test conducted by Lubrizol has shown that deposits on the intake valve and EGR increase significantly in DI engines when using conventional Euro 3 type oils, as opposed to using Euro 4 type oils (i.e. lower SAPS) such VW 504/507.
    Now I can't confirm if that alone can eliminate the problem entirely, but it is certainly one the easier methods to try out!
    In regards to cost, unless you are happy being charged $25/litre, you can easily find cheaper alternatives in stores or online.
  6. #26
    If you have seen the full new range of VW engines due for release, you will see what they have done to solve the issue - anyone have a guess as to what they have done?
  7. #27
    Jan 2012
    Epping, NSW
    Ok, my guess is a 5th injector in the throttle body..
  8. #28
    Dec 2007
    Girraween
    second set of injectors and fuel rail
    Im interested to see how the fuel system is before that and how its split
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
  9. #29
    Sebs got it! - it's a new split fuel system, from the technical documents, the port injection is transitional "low" pressure.
  10. #30
    Apr 2006
    VW Race HQ - Sydney
    Wait , what ? Thats Courtney that posted , although I knew about what they were doing a few years back .VW/Audi never aknowledged it was an issue publicly but they changed the injection design back to conventional multi-point and kept direct injection ! Expensive learning curve where 10 years worth of FSI cars will suffer issues !
    Bug_racer supports the rebellion of the euro revolution
