Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Crunch during cold start.
    Dec 2009
    Canberra
    Quote Originally Posted by jameshero View Post
    Anyway of proving it or getting the dealership to act on it?
    I found that if i drove the car for a little, then left it off for 20-30 minutes and tried to start the car it would make the crunching/rattling noise 9/10 times.
    I did this with the mechanic present and they sorted it out.
    Dec 2009
    Sydney NSW
    Quote Originally Posted by thewafflecaust View Post
    and the cause was ?
    mk VI GTI, manual, reflex silver, basic
    Dec 2009
    Canberra
    Quote Originally Posted by mfl View Post
    and the cause was ?
    See above or below..
    Its the cam adjuster/positioner.
    I believe this is the bulletin for it
    TPI - 2009810/18 23.08.2010
    WA
    I frequently got a crunching noise backing out of the driveway in the mornings. Realised after a while it was the fallen nuts from a palm tree near my driveway
    2010 MY11 Mk VI Golf GTI [5Dr|DSG|Carbon Steel|MDI|Bluetooth|Street Legal Tint]
    2008 Chrysler Grand Voyager Touring [Diesel|[COLOR="black"]Black[/COLOR
    Jun 2011
    N/A
    Hey Guys,
    Thanks for the responses so far. After minke suggested that the AC engaging may be responsible, I've started switching the AC off before switching off the car. However yesterday morning the car made the noise again. Also noticed that the revs drop 100-200rpm for a second when the noise occurs, and then spring back up again, which would seem to be consistent with something engaging, however the AC was off so it can't be that. Might also be worth mentioning that the car sat for 2 weeks in January and the first time I started it up the noise was considerably louder than it had/has been before.
    Quote Originally Posted by Umai Naa!! View Post
    it's the coolant circulating in the heater core under the dash when you start the car.
    This wouldn't cause a drop in revs would it?
    Quote Originally Posted by wai View Post
    Is your foot on the brake or off?
    On
    Can you feel anything through the gear lever?
    Nup
    Things that come to mind are the clutch throw our bearing.
    Think the dealership may have replaced this before replacing my pressure plate in an attempt to stop a squeaking clutch. Noise was apparent before and after it was replaced though.
    Have tried leaving it for 30 minutes a couple of times but it seems to only happen when the car has fully cooled down. Long enough that my car does that high idle thing to warm up. Would the cam adjuster cause a drop in revs?
    Jul 2012
    Sinagra, Western Australia
    A/c compressor uses a valve to regulate itself, magnetic clutches are SO 2008. So that will not be causing your noise.
    It could possibly be the cam positioner/adjustment valve, which would explain both the noise and RPM drop(rpm will rise/fall in relation to timing advancement or retardation).
    There is a common issue with them, unfortunately that is how most warranty systems work. Before anything can be done, the fault has to be confirmed. What I would suggest to you is dropping the car overnight and then going in for the morning before they start it so you can demonstrate it. Usually the poor tech is only getting "Noise from engine when cold", so when they are testing it they are trying to hear a million different things.
    Hope that helps.
    Dec 2008
    Sydney/Canberra
    Yeah, once you've told the service advisor of your concerns, it's all Chinese Whispers from there.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2009
    Canberra
    As others have suggested, leave the car with the service center overnight/for the day and have them start it from cold.
    I don't remember if mine dropped in revs much, but everything you describe sounds the same as the problems i had.
    Jun 2011
    N/A
    Will have a chat to them on Monday and organize a time to bring it in.
    Thanks again for your help
