Page 1 of 5 123 ... LastLast
Results 1 to 10 of 92
Thread: Coolant levels
REXman Coolant levels 05-03-2011, 05:56 AM
MurphyTheElf I had a similar experience... 05-03-2011, 11:21 AM
Pepe +150kwatw for you if they fit... 05-03-2011, 11:48 AM
zbeasty I checked mine today and its... 05-03-2011, 06:16 PM
Sir_GTI I had the same issue on my... 06-03-2011, 09:36 AM
DDTW Thanks Corey! 24-05-2011, 09:25 AM
Transporter Get them to check your water... 24-05-2011, 09:32 AM
DDTW Thanks for the tip mate :) 24-05-2011, 11:17 AM
AJW http://www.vwwatercooled.com.a... 24-05-2011, 07:03 PM
markwid Done about 3,000 km. Level ok... 24-05-2011, 08:24 PM
DDTW I've only done 2600kms! Very... 24-05-2011, 08:36 PM
Maverick Why? The car is under... 24-05-2011, 09:20 PM
DDTW Calm down Mav. To me,... 24-05-2011, 11:39 PM
dave_r Don't open the bonnet,... 25-05-2011, 02:26 PM
NiNo_LoCo So I picked up my R last... 24-05-2011, 09:44 PM
HPSOV 0km Coolant and oil were both... 28-05-2011, 06:16 PM
DDTW Yeah my engine was cold when... 28-05-2011, 08:49 PM
Corey_R So now you just need to buy... 28-05-2011, 09:20 PM
NiNo_LoCo had a call from my VW dealer... 30-05-2011, 04:21 PM
Lucas_R After 1,600kms - i decided to... 30-05-2011, 04:28 PM
scozzy Mk6 R Coolant dumped 21-03-2012, 10:45 AM
Lucas_R No idea mate unfortunately -... 21-03-2012, 11:38 AM
scozzy Yeah there stock is a... 21-03-2012, 03:03 PM
Lucas_R See link for photos and... 21-03-2012, 08:36 PM
mythik I bothered to look at my MY12... 22-03-2012, 01:53 PM
VeeDub23 Hi. I've been driving my... 27-07-2012, 08:24 PM
Transporter Very unprofessional to say... 27-07-2012, 08:35 PM
DeanoTDI 115'000km and Coolant/Oil ran... 15-10-2012, 03:12 PM
stickshift3000 If you're not happy with the... 15-10-2012, 03:44 PM
gldgti Given the things you have... 15-10-2012, 03:52 PM
Umai Naa!! The engine oil could've been... 15-10-2012, 04:17 PM
DeanoTDI The EGR leakage was another... 16-10-2012, 01:37 PM
Jmr84 If your egr cooler is leaking... 16-10-2012, 08:44 PM
minke Coolant Level GTi (MY13) 21-04-2014, 10:01 PM
jboogie system is closed and under... 21-04-2014, 10:10 PM
minke Not that I could eye ball in... 21-04-2014, 10:23 PM
Snail Style When are you checking the... 22-04-2014, 06:34 AM
minke both - consistently same... 22-04-2014, 06:38 AM
gazzmo Actually the coolant level... 22-04-2014, 08:24 AM
Snail Style To check the level, no it... 22-04-2014, 06:19 PM
sVWatt Mine has sat on the minimum... 23-04-2014, 04:52 PM
Diesel_vert Please read the owners manual... 23-04-2014, 05:49 PM
minke Advice : Coolant level... 26-09-2014, 07:50 AM
VR28LT you should always be checking... 26-09-2014, 08:47 AM
piper26 When your car is cold set... 13-10-2014, 07:55 PM
    May 2010
    Coolant levels
    Not sure if it's a 'characteristic of the R or not, or maybe my dealer forgot to top up the coolant..? But went to start my car this morning.. And I am now unfortunately copping the coolant/engine temp light flashing.
    Manual says check coolant and low and behold my coolant levels are below the MIN line?
    The car is 3 months old and it surely can't get through a whole supplies worth of coolant in less than 4000kms driven.
    Any other owners experience this? Could be the nature of the car being operated at a higher temp than non sports models.. Or it could be just my dealer didn't top it up..
    No leaks there are no visible drops at all, anywhere in or near the car.
    Ideas/any other MKVI golf owners experience this?
    Friggin wierd, I havent had that on any other car I have owned.. Even old ones..
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
    Sep 2009
    Perth, WA
    I had a similar experience earlier in the week.
    Within a few minutes of driving the car, the MFI chimed and warned "check coolant level", despite the engine and water temperature being normal. I pulled over immediately and saw that the coolant was just below the Min marker. I also checked the bottom of the car and saw some water dripping off the chassis - not where an overflow tube should be. I didn't have any G12 Plus coolant, but I wasn't far from my dealer so I just drove straight there (ensuring engine and water temps didn't increase abnormally).
    Turns out the water pump has a leak and is being replaced under warranty. The only problem is the they ordered the Golf R water pump so they have my car all weekend now thanks to the transit time for parts stocked in the east.
    I have a TDI Jetta slushbox as a loaner. Boo-urns.
    GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
    Quote Originally Posted by MurphyTheElf View Post
    +150kwatw for you if they fit that water pump then
    Jul 2010
    St Ives, NSW
    I checked mine today and its sitting below min whereas when I checked it the other week it was fine. The low coolant light hasn't come on yet so obviously hasn't gotten as low as REXman. I noticed that there are marks in the area around the coolant tank that look like it has been releasing water. Was at my dad's so we checked both the cap, releases at above 22psi, and the rest of the system which held pressure at 20 psi. Also checked that the hose clamps were tight and couldn't find anything. Will have to get some more coolant on Monday and top it up. Made sure to keep an eye on the temp gauge on the way home and it didn't move.
    Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune.
    Mar 2010
    I had the same issue on my GTI. Had about 14000 on the clock and the warning light came on one night. I pulled over, had a look and it was below min as well.
    Toped it up, and had it at the service centre the next week for its 15k service. Mentioned the issue, and they had a look.
    I know have a sticker next to the service sticker, advising to bring the car back in 6 months (after the service) and have them re look.
    I only had to refill it the week after the service, and now 5 months later, I have had no further issues, or needed to top it up.
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
    Dec 2008
    Sydney/Canberra
    Quite often what happens is the cooling system has not completely burped when the car was built. So, once the car has been driven for a sufficient amount of time with it's new owner, the remaining air bubbles in the system are bled out. You'll usually only lose the contents of the expansion bottle at the very most.
    While VW pumps the coolant into the cooling system as a closed circuit, in the theory of no ar bubbles, it never seems to work 100%.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Nov 2010
    Melbourne, VIC
    Thanks Corey!
    Adelaide hills, SA
    Quote Originally Posted by DDTW View Post
    Thanks Corey!
    Get them to check your water pump as well and keep an eye on it.
    Nov 2010
    Melbourne, VIC
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
    Apr 2010
    Interesting.
    I was looking at mine on the weekend without seeing this thread , took a photo and was about to post a new topic.
    I've stuck some tape on mine near the current level so I can see what it's doing.
    I also had a look at my wife's EOS with the previous 2T engine and it seemed to be filled up to the middle level.
    Would be interesting to see what other people show.
    (Done about 7K)
    MY21 Golf MK8 GTI | Kings Red Metallic | all options |
    MY16 Golf MK7 GTI PP | White | With Leather |
    MY11 Golf MK6 GTI DSG | CW | 5dr | Bi-Xenons | ACC | 18" Detroits | RNS510 with Dynaudio| RVC | MDI |
