Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: Coolant levels
  1. #21
    Oct 2010
    Perth
    I had the same situation after having my GTI for about 3 weeks. The coolant was below the minimum line............................BUT............... .after opening the lid, the coolant level rose back up slightly and I could hear all that warm air hissing out.
    Bought the coolant, mixed it and then topped it up. Been checking my coolant and engine oil levels every few weeks and topping it up if necessary. Did not expect to do it so often to be honest. Could be the hot wheather.
  2. #22
    Nov 2010
    Melbourne, VIC
    Hi team,
    Just did a random check on my coolant and was shocked to see the level:
    G12++ you guys said? I'll either try buying it or go back to my dealer for a top up.
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
  3. #23
    Feb 2009
    Sydney, Australia
    Yep mate. G12++
    I got a bottle (1.6L or something) from my APR dealer in Sydney last time I was there for about $20 or something. However, I'm sure that any VW dealer would be happy to top it up for you if you dropped into their service dept.
  4. #24
    Nov 2010
    Melbourne, VIC
    Thanks Corey!
  5. #25
    Adelaide hills, SA
    Quote Originally Posted by DDTW View Post
    Thanks Corey!
    Get them to check your water pump as well and keep an eye on it.
  6. #26
    Nov 2010
    Melbourne, VIC
    Thanks for the tip mate
  7. #27
    Apr 2010
    Interesting.
    I was looking at mine on the weekend without seeing this thread , took a photo and was about to post a new topic.
    I've stuck some tape on mine near the current level so I can see what it's doing.
    I also had a look at my wife's EOS with the previous 2T engine and it seemed to be filled up to the middle level.
    Would be interesting to see what other people show.
    (Done about 7K)
    MY21 Golf MK8 GTI | Kings Red Metallic | all options |
    MY16 Golf MK7 GTI PP | White | With Leather |
    MY11 Golf MK6 GTI DSG | CW | 5dr | Bi-Xenons | ACC | 18" Detroits | RNS510 with Dynaudio| RVC | MDI |
  8. #28
    Feb 2010
    Done about 3,000 km. Level ok but I suspect will need top up not far down the road.
    2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
  9. #29
    Nov 2010
    Melbourne, VIC
    I've only done 2600kms! Very worrying.
  10. #30
    Jan 2008
    Why? The car is under warranty, you're aware that it's low, there is a warning system there if it does drop too low so what is there to worry about when there is an explanation given by a dealer about why it could drop a little?
