Doesn't everyone read the manual cover to cover when they get a new car?
Anyway, flash the high beams to turn on the "coming home" function. Essentially you have to manually turn it on every time you want to use it.
As for the cornering fogs, can't really help you there asI mine worked from factory, but it's likely to be a VCDS coding this if they aren't already on.
