Results 1 to 7 of 7
Thread: Coming home lights don't stay on? and how do i activate cornering fog lights?
    Jan 2011
    Northern burbs, VIC
    I have a 2012 mk6 golf gti and have the following questions:
    The option in the MFD is checked, the leaving home function works but the coming home function doesn't?
    Headlights are switched to auto but when I turn the car off, the headlights turn off as well.
    Also, how do I activate the cornering fog lights?
    Feb 2013
    Quote Originally Posted by kopite View Post
    what exactly is the coming home function
    im picking my jetta up in a couple of weeks and it has this as well
    Dec 2006
    Kilsyth, VIC
    Doesn't everyone read the manual cover to cover when they get a new car?
    Anyway, flash the high beams to turn on the "coming home" function. Essentially you have to manually turn it on every time you want to use it.
    As for the cornering fogs, can't really help you there asI mine worked from factory, but it's likely to be a VCDS coding this if they aren't already on.
    Jan 2011
    Northern burbs, VIC
    Coming home - when you park your car, the headlights stay on for 10 secs or whatever time you set it to.
    Leaving home - when you press the unlock button, the lights will come on for 10 secs or whatever you set it for
    Jan 2011
    Northern burbs, VIC
    Quote Originally Posted by The_Hawk View Post
    Dog ate my manual
    Jan 2011
    Northern burbs, VIC
    Thanks anyway..
    topic closed
    Nov 2009
