![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Lucas_R
There's some sort of blockage/supply issue with your fuel system. Have you had the fuel filter replaced? Cheap and easy to do yourself and that will eliminate 1x possibility.
The fuel line runs up the drivers side of the car (and fuel filter is just in front of rear drivers side wheel) so might be worth checking fuel lines arent bent/damaged in any way from hitting road debris etc? They are pretty well protected but you never know.
The in-tank low pressure fuel pump might be weak also. This feeds fuel up to the engine then the HPFP pressurises it to be direct injected into the cylinders.
Makes sense that it only appears when you go WOT as this is when the fuel system is under max demand so any issues will arise at this time.
