The brake pads can move slightly in the calipers, so it may be that what you are hearing is the pads moving to the opposite limit of their movement with the discs going in reverse. Does it keep doing it? I.e. if you reverse, brake, it makes the clunk, does it do it again if you reverse and brake without going forwards in between?
