Results 1 to 10 of 67
Thread: How to: Upgrade to an RCD510 in Mk6 Golf
    Sep 2009
    Melbourne - Vic
    Hi,
    I managed to get a second hand RCD510 to replace my bog standard RDC300 in my MK6 2.0 TDI.
    Her's the how to" if anyone else is going to do the upgrade and save about $170 in "dealer labour".
    Tools needed:
    Strong finger tips
    Torx 20 driver (star shaped hex key)
    2 highly polished smooth edge teaspoons
    A large soft pillow (don't tell the Mrs)
    And the new radio and security code.
    Procedure.
    Insert your fingertips beneath the radio surround just above the climate control fascia.
    Using equal force, pull or lever the bottom of the radio fascia out about 10 millimetres.
    Leaving one hand trapped under the fascia, insert the handle end of the spoon just into the gap exposed on the side of the fascia panel.
    With some dexterity, do the same on the other side.
    Grasp both spoons and pry the panel toward you, moving up to the top of the panel.
    Some clicking will be heard as the tabs release, don't panic. As long as no serious bend develops in the panel you are OK.
    Once the panel has started to ease you can ditch the spoons and use your fingertips to pop the rest of the panel out.
    When that's done, use the driver to unscrew the four "star" head screws out.
    Ease the radio forward under control until you can see the antenna and cable unit connections.
    Support the radio with one hand (or the pillow if you have little hands)
    Tilt the unit to the left and observe the antenna wires and connection point on the rear lower corner.
    Slide the small white latch on the base of the connection out from the radio and you should be able to wiggle the antenna cnxn off.
    On the other side there is a large loom of wires held by a lever block.
    Lift the lever from the bottom of the block and withdraw the cnxn block.
    The old radio unit is now free to place on the passenger seat.
    To install the new unit, reverse the steps (i.e. hold in one hand, insert the big wire block, snap the lock down, insert the antenna loom, push the tab in, slide the box into the cavity, replace and tension the screws (gently) and position the fascia panel and using thumb pressure, pop all of the tabs back in.
    It make make some CD hunting noises as power hits it but that's OK.
    When prompted, enter the security code and you are on your way.
    All up it takes about 10 minutes.
    If anyone needs pics or advice, just IM me.
    Jim
    Feb 2009
    Sydney, Australia
    Thanks for posting that information. Maybe there should be a 'how to' tag on that post (and all other how to posts) to make them easier to find !?
    Dec 2008
    Sydney/Canberra
    Good work, mate.
    That's exactly how easy it is
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2010
    Strathfield, NSW
    Great! Can we do the same with RNS510? There are ones selling on ebay.
    Is it that easy ?
    What's all this talk about codes then ? Everybody in these forums keeps talking about VAG and codes and crap that most average people have no idea about.
    I've heard installing the RNS-510 yourself is not possible.
    Dec 2008
    Sydney/Canberra
    RNS510 is a little trickier, but if you're local-ish to me, I can certainly help you out.
    '01 Beetle 2.0
    Oct 2009
    WA
    Quote Originally Posted by JonoB View Post
    Is it that easy ?
    Apparently it is possible e.g. VWvortex Forums: RNS-510 Install: MkV R32
    and for the Mk6 some info http://forums.vwvortex.com/zerothread?id=4748187
    Jan 2012
    Gold Coast QLD
    Quote Originally Posted by jy01752684 View Post
    Only thing is installing the antennae also which runs up through the dash.
    Apr 2010
    Thanks Rob (although the thread is over a year old)
    Jul 2010
    Melbourne, Victoria
    Can you swap standard golf (wagon) head unit with a RCD 510 ?
    Hi all, just need some answers from people who may know better.
    Can the stock standard base stereo head unit from a 2010 golf wagon be removed and replaced with an OEM RCD 510 from a Golf?
    I know it will fit, but will everything on the back connect as per normal or will some modifications or wiring loom need to be changed?
    Also, does this provide better audio output over the stock system?
    I hope this all made sense as I'm new to these cars and systems.
    Cheers-
