Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 120
Thread: Checking Engine Oil Level / Oil Consumption / Oil Light On
  1. #71
    Pacific Paradise QLD
    GTI is petrol.
    GTD is diesel
    Tell me about Nulon again?
    Full Synthetic 5W-30 Diesel Formula Long Life Engine Oil- Nulon Australia
  2. #72
    Jan 2009
    Quote Originally Posted by ratsock View Post
    Hey guys,
    As in subject title, I'm a total noob when it comes to this stuff. Am trying to learn one step at a time from the very beginning
    So my GTI DSG has got the oil warning light on. I figure this is pretty urgent I'm just wondering which oil you guys recommend for use in topping it up? I looked up the shell and castrol sites and they recommend the 5w-30 for this model, but I've seen other sources saying 5w-40. What's the difference? Does it matter which?
    Volkswagen does not specify a specific viscosity grade for most of their vehicles.
    However, Volkswagen (like many other vehicle manufacturers) set their own standards, specifications and test procedures for a vast variety of fluids and lubricants - including engine oils. But this does not mean you must only use VW-branded oils.
    VW make the specifications available to interested parties, such as lubricant manufacturers, who can decide to submit their product to VW for evaluation (which I'm led to believe costs many hundreds of thousands of dollars for engine oils) to gain VW certification and approval.
    Products which are submitted and have passed VW test procedures are put onto a list of approved oils, which is maintained by VW - these are usually (by not always) referred to as OEM approved oils or lubricants.
    To that end, the relevant oil standard and/or viscosity grade that is required for your vehicle is usually listed in the owner's manual. Today, for ordinary VW passenger vehicles, this is usually:
    VW 502.00/505.00
    -- or --
    VW 504.00/507.00
    As mentioned, VW do not specify a viscosity grade for most of their vehicles.
    Products that do not appear on OEM approval lists is not necessarily an indicator of a product's quality per se (plenty of high-performance & high-quality lubricants carry no costly OEM approvals), but it does raise the issue of liability during the warranty period. In the unlikely event of an engine failure caused by deficient lubrication, where the lubricant in question has claimed to meet and exceed the relevant OEM specification, it may take some time for the party responsible (either the vehicle or lubricant manufacturer) to accept the of cost of repairs before any such repair actually commences, which may cost the consumer lost time and inconvenience if it isn't resolved promptly.
    However, I would assume no liability on part of the vehicle or lubricant manufacturer if the consumer does something silly like pour a mineral 20W-50 oil (or whatever) into a Volkswagen that's still under warranty.
    Problem is my gf drove it around for a while (maybe an hour or two) during the week with the light already on before I got to take a look, so I'm pretty paranoid about driving it any more. The car is pretty new <4k km so I'm surprised it ran out this fast, I would imagine it wouldn't usually need an oil top up at least until 5k?
    Many people have reported and experienced higher than anticipated levels of oil consumption in vehicles made by the Volkswagen Group (which includes Audi, Seat and Skoda, amongst others).
  3. #73
    So I shouldn't use Castrol Magnatec? Like I did in my Polo ??
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  4. #74
    Jan 2009
    Quote Originally Posted by sVWatt View Post
    Check the label.
    If it has either VW 502.00/505.00 or VW 504.00/507.00 written on it, then it's fine.
    Otherwise, I'd save it for a less stringent or less demanding application.
  5. #75
    Jan 2011
    Brisbane - QLD
    For all new Golf cars, only use VW 504.00/507.00 oils.
    Use any non VW 502.00/505.00 or VW 504.00/507.00 approved at your own risk.
    /close thread!
    MINI Cooper S Clubman - FWD
  6. #76
    Jan 2009
    Quote Originally Posted by nat225 View Post
    /close thread!
    Although I also personally recommend using 504/507 oils for any direct-injection petrol engine, it isn't compulsory unless the vehicle is on the LongLife service regime - which should not be the case for any Australian delivered VW.
  7. #77
    Basically what we are trying to say is stick to VW APPROVED OILS of the correct type and you wont have any troubles with warranty.
    Use something else and it may well come back to bite you for the sake of $25 an oil change.
    I have posted a link to an extensive list of approved oils.
    They are listed both under types and separately alphabetically
  8. #78
    Erskineville, NSW
    /close thread!
    Incorrect. Suggest you read your owners / service manual.
  9. #79
    Jan 2011
    Brisbane - QLD
    I will leave that comment for more confusion then
  10. #80
    /close thread!
    Perhaps you actually meant this
    Use any non approved VW502/505 or VW 504/507 at your own risk
    Meaning ONLY USE APPROVED OILS
