Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 120
Thread: Checking Engine Oil Level / Oil Consumption / Oil Light On
  1. #31
    Adelaide hills, SA
    More information about checking engine oil level
    Quote Originally Posted by brad
    In the General Maintenance section of the manual under the section "Check Engine Oil Level".
    Definitely says that when new the oil level should be checked at every tank fill.
    Brad
  2. #32
    Sep 2010
    I had got into the habit of only lifting the bonnet just before the service to see if any oil had been used - which it never had - but now I find that I'm adding a litre every 5th tankful. It's the first time I've added oil to a car in the last 12 years. It's a bit like I've gone back to my original '77 Golf. Since the 15,000km service the oil consumption has dropped off markedly and I haven't topped it up yet but can see it will probably need it sometime.
    Nov '15 Polo 81TSI manual white
  3. #33
    Adelaide hills, SA
    Quote Originally Posted by Mountainman View Post
    Every internal combustion engine will use oil. Even if the oil level on dipstick is the same, it only means that unburned fuel, dust and dirt took the place of burned (used) oil.
    Your '77 Golf was using 15W40 or 20W50 oil and your new car engine uses 5W30 that's why moder engines today use more oil than in the past.
  4. #34
    Sep 2009
    seaforth, nsw
    check oil light came on at 5500km
    so i start up mjy car and the check oil light has come up, ive only done 5500km.
    ill head to the dealership and ask for a top up cos no way this should be normal, considering they expect services to be every 15k km.
    i think ill buy some oil while im at it
    any others with this experience
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
  5. #35
    Jun 2011
    Hey mate.. What's the level of oil showing on the dipstick?
    captain courteous enjoys vag
  6. #36
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by walbjj View Post
    It's quite normal, as per your owners manual, and as per this thread.
    Go to your dealer, they will happily top it up for you.
    New cars can use more oil due to the break in process. It's your responsibility to ensure that you check the levels regularly....
  7. #37
    May 2010
    Quote Originally Posted by Corey_R View Post
    My dealer wasn't happy to top it up for me.
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
  8. #38
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by elephino View Post
    Find a new dealer then
  9. #39
    Erskineville, NSW
    No, I've never noticed any discussion on oil usage on this forum. I'd think you are in a unique situation.
  10. #40
    Jan 2011
    Brisbane - QLD
    perhaps less common in the Mk6? more common in Mk5?
