Results 1 to 10 of 12
Thread: Carbon Buildup..
    Apr 2010
    Carbon Buildup..
    What do you guys feel about this? I have APR 2+ GTI that's about to go in for a 60k service and also will fit in a BSH race catch can. Do you think its necessary for a full upper engine clean. I know you can use a spray can upper engine cleaner but im not sure if it will clean the hard deposits of carbon.
    Adelaide hills, SA
    Quote Originally Posted by Parky View Post
    I would clean the intake system every 15,000km on TSI engine. At 60,000km you will not be able to remove all the deposit. Catch can or Provent is a good idea.
    May 2009
    Seb in Girraween does full strip down engine cleans. Apparently the only way to make sure all the gunk is removed.
    Contact details found here:
    http://www.vwwatercooled.org.au/f12/...dney-3076.html
    Mar 2010
    Transporter, what product would you suggest to do the clean?
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
    Adelaide hills, SA
    Quote Originally Posted by Sir_GTI View Post
    WURTH Intake system cleaner - it could be harder to get, you will need to find the WURTH distributor. I could help you, if you were in Adelaide.
    Motorcrfat R16 - from Ford dealer or Motortraders.
    Amsoil Powerfoam (similar to Motorcraft R16) from Amsoil dealer in your state.
    Mar 2010
    Thanks Transporter, I will have a look and see what I can find.
    Are these just a spray type cleaner?
    Just trying to figure out if it will be an easy job every 15k, or if it will require some downtime.
    Aug 2009
    Any reason for those over something more readily available like the Subaru branded 'Upper Engine Cleaner' product?
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Apr 2010
    Will these spray can upper engine cleaners actually work with hardened deposits of carbon ?
    Adelaide hills, SA
    Quote Originally Posted by break View Post
    Subaru upper engine cleaner is the same as Ford Motorcraft R16, both made by Bars Leaks. Ford will be cheaper and if you could get Amsoil PowerFoam you get more product for less.
    Adelaide hills, SA
    I have good results with WURTH and Ford R16. WURTH comes with long plastic tube that you can get very close to the inlet valves in some engines.
