Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: Car bucks and jerks when cold below 2000 rpm
  1. #31
    Sep 2011
    Strathfield, Sydney
    Quote Originally Posted by Reedy View Post
    Hey mate, my new intake goes in on Monday. I'll let you know the morning after how it drives but I'm pretty sure it's all related. Let you know Tuesday morning.
    Thanks Reedy. Fingers crossed
    2005 VW MK5 Golf GTI
    2008 VW MK5 Golf GTI
    2011 VW MK6 Golf GTI
  2. #32
    Jan 2012
    Quote Originally Posted by dimi_108 View Post
    Intake manifold is in and runs loads smoother with no rattle or sputter when I hold it at 1400 rpm. It has not fixed the cold start splutters though but they don't seem as bad and it clears up quicker, but my car did run crap at low rpm and light throttle due to the manifold. Might try a new pre cat O2 sensor, I've already put in a coolant temp sensor.
    2015 Golf R. Lapiz Blue.
  3. #33
    Jan 2012
    New intake manifold in. Runs like a dream but still have little jerks when cold under light throttle and lie rpm. After 2 minutes of driving there are no issues. With 130000klms on the clock I can live with this.
  4. #34
    Aug 2008
    Similar thing on my 2.0T also, around 2500rpm'ish only when the engine oil temp is less than 50 degree celsius or so. Occurs only when I run 5w30 oil, but doesn't do it when I run 0w40
    Hers: 2012 MY12.5 VW Jetta 147TSI Comfortline, Tornado Red, stock !
    His: 2007 MY07 Audi A3 Sportback 2.0T quattro, Lava Grey, many, many, many mods, 196kw ATW
    Previously: 2006 VW Passat V6 4motion, 2003 VW Golf GTI, 1998 Passat 1.8T
    On it's way: 2015 Audi S3 Sedan !!
  5. #35
    Jan 2012
    Just ordered pre cat O2 sensor and an intake temp sensor just to see if these improve this issue. I've no faults but with the high klms it's probably about time I cleaned and replaced some sensors.
  6. #36
    Sep 2011
    Strathfield, Sydney
    Did the intake manifold solve the problem? No more jerking etc? Or are you still getting the small misfires?
    Quote Originally Posted by Sloth View Post
    That's interesting that you mention the oil. Mine is exactly the same and will jerk around when the oil temp is less than 80-90 degrees. After that, the car is as smooth as can be.
    Thanks for the info btw. Going to give 0w40 a try on the next oil change
  7. #37
    Jan 2012
    No intake manifold didn't fix the issue although the car does run better but my manifold was shot. Jerking is not as violent and is quicker to clear up, around when oil temp is 60+. I'm going to try a new manifold temp sensor and pre cat O2 sensor.
    Ozzy
  8. #38
    Jan 2012
    Just found this, it's an old thread but is almost the same symptoms as what I'm having in this thread and my other thread regarding clutch issues. Ant thoughts would be appreciated.
    DTC - 17947 Clutch Vacuum Vent Valve Switch...just had this replaced... - AudiWorld Forums
    DTC 17947 - Clutch Pedal Switch (F36): Implausible Signal...anyone ever get this? - AudiWorld Forums
    Ozzy
  9. #39
    Jan 2012
    Thought a video might help.
  10. #40
    Jan 2013
    Brisbane, QLD.
    Hey Reedy.
    Watched your video, so it seems to be a 'clutch' related issue, e.g: when you're operating the clutch the stumble and fuel consumption figures seem to be affected, yet when no operation of clutch everything seems normal?
