Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Can you turn off the seatbelt warning "ding"?
  1. #21
    Guest Guest
    just need to change your coding via vagcom is very easy need to change the country in dash coding
  2. #22
    Aug 2009
    Melbourne, Vic
    I reckon it is simpler and makes more sense to to select "seat belt warning" off than to change country setting with VagCom if thatis all you want to change. Changing country may have other undesired effects. As mentioned three posts up #17.
  3. #23
    Guest Guest
    Quote Originally Posted by logger View Post
    yeah sorry i was thinking of older dash's golf V and such yeah seat belt warning off sound alot easier
  4. #24
    Dec 2010
    how to disable the seatbelt alarm.
    I know i prob should not be doing this. But i really want to disable the passenger seatbelt alarm. I often do the grocery shopping and put in on the front seat or have my dog ride up front with me and the alarm is constantly going off.
    My question is...is there a way to disable the alarm/bell sound without affecting any other services such as airbags ect.
  5. #25
    Oct 2006
    Yeah u can do it but u need vcds and a genuine rosstech cable. I borrowed one off a friend and disabled the seatbelt reminder.
    http://www.vwwatercooled.org.au/f112...ary-50749.html
  6. #26
    Feb 2009
    Sydney, Australia
    Or just put the selt belt in the buckle, even if you're not securing a person with it!
  7. #27
    Dec 2010
    Quote Originally Posted by Corey_R View Post
    Yeah, I actually tried that for a while but it just causes more problems than its worth. the dog getting tangled up ect.
    I was just wondering if there was going to be a easy way but i guess not. ergh....
  8. #28
    Nov 2009
    Quote Originally Posted by cs3110 View Post
    Sure there is. See this thread for the details of a member nearby who can help you disable the chime. The instructions are in this post (see tweak #3). Easy!
  9. #29
    Isn't you dog meant to be restrained in a moving car?
  10. #30
    Jan 2010
    Springwood
    usually, it just uses the buckle to activate a switch..
    if you look at the wiring in the seat, closing the circuit should appear as though the belt is on.
    VCDS change is a better option as it's reversible.
    Alternatively, you could get a spare buckle from a wrecker, and just plug it in...
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
