Results 1 to 7 of 7
Thread: Buying VCDS
    Oct 2019
    Buying VCDS
    Hi guys,
    Sorry for my lack of knowledge with this topic however I was after a VCDS Ross-Tech to add some features to Mk6 golf (add navigation to the MFD after I installed RNS510 and also whatever other features I can get going with my car).
    Is there anywhere in Australia to buy these from or as if I’ve read in other forums, it’s recommended to try find someone with one and ask them for a hand. I’m located in Brisbane if someone is willing to give me a hand for $$$ or carton
    Pacific Paradise QLD
    You want to buy one ($450) or get someone to do a few little mods for you??????? Suggest the latter if you arent at all familiar with them
    Oct 2019
    You want to buy one ($450) or get someone to do a few little mods for you Suggest the latter if you arent at all familiar with them
    Thanks for your help man, really appreciated
    Dec 2006
    Kilsyth, VIC
    They aren't cheap, so if it's just a handful of things you want to do, check out the forums for what's possible then get someone to lend a hand to get you going.
    With a Mk6 you can use the older HEX+CAN does everything you want, if also have newer vehicles, or want to plan for the future, then the newer HEX-NET cables are for you.
    The older cables are floating about as people upgrade to the newer ones, so keep an eye out. If you look to the newer ones, be sure you're aware of the difference between personal (10 VINs) and Professional (Unlimited VINs) and what they could mean for you in the future.
    The other alternative is OBD11 if you have an Android device, not something I have looked into personally, but people have it and seem to like it.
    Bottom line, do you want to be doing stuff with your car in future, or is this it? Also remember that cheap OBD adaptors might not be able to do all the changes, but they can still read and clear codes if all you want is to be able to scan for errors from time to time.
    Nov 2007
    PM me when you are ready (as in after you installed the RNS510 unless you need help with that too) and I can help you. I have VCDS suitable for the MK6.
    This reminds me, I really need to upgrade my VCDS as 2 modules on my MY19 Golf R cannot be read with my HEX+CAN
    Why I suggested what I did is because seems the OP has no experience with any of them and while everyone has to start somewhere it is better to watch someone do a few things and have it explained, rather than rip in and cause yourself problems.
    I remember early on in my experience I got another person to do something and we changed the wrong thing and hadnt saved original settings. Never did find out what it did but didnt seem to affect anything but was a foolish thing to do OBDELEVEN hasnt got much on Golf Mk 6 as is oriented to the MQB platform
    Oct 2019
    Really appreciate your help guys, before this thread everything online was confusing or overseas. Thanks again!
