Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Bumpy Ride in Sport suspension mode
    Mar 2007
    Country NSW/Southern Tablelands
    UPDATE: Camber was actually fine. Both front electronic height sensors now replaced. No luck though.
    Getting a local Porsche mechanic and suspension specialist to do a proper wheel balance to see what effect that has.
    Problem most notable on smooth roads at about 80kph in Sport mode. If not wheels or suspension then could be a diff issue.
    Will report back.
    Man In Black (MIB)
    2007 V6 4Motion Passat, Black, Leather, DSG, 18" Wheels, Bi-xenons
    2010 Mk 6 Golf R, 5-dr, Rising Blue, DSG, leather, ACC, RVC
    Mar 2007
    Solved.
    After much investigation (and new rear Shocks and rear diff end dampener) turns out it was a flat spotted tyre. Only one. That's why it didn't vibrate through the steering.
    Flat spotted meant an up and down movement not a left right vibration (which you would normally feel through the steering). This is why the chassis control could control it in comfort but transferred the movement to the car's chassis in the less compliant sport mode. Effect was only felt around 80 and 100 and would go away when the tyres were hot.
    Took it to a tyre/wheel expert in Mitchell in the ACT who pretty well diagnosed it from my description. We then ran them up on the balancing machine and one stood out (visually) as not being quite round.
    No explanation for the flat spot. Could have been tyres where hot and I parked one tyre in cold water which changed its shape.
    Anyway, real happy it's not the car's fault. Pretty annoyed with Jax at Fyshwick who I took it to 6moths ago for a balance and rotate and to find out what the problem might be. They should have seen the flat spot and reported it to me.
    Man In Black (MIB)
    Aug 2013
    Kellyville, NSW
    Good to know it's fixed.
    Strange you had no feel for the flat spot through the steering though...
    Mar 2007
    Shock absorbers were taking all the load so it wouldn't transfer through the steering. Left right movement/vibration would have been sent down the shaft and then to the wheel.
    Certainly speaks volumes for the chassis control that it could hide it in comfort mode.
    Man In Black (MIB)
    Jan 2011
    Melbourne Australia
    takes a while to get a flat spot ?
    as in, parked in the same spot for a couple weeks, not overnight...
    Jan 2009
    Quote Originally Posted by Man In Black (MIB) View Post
    That's not a fair summation to blame a workshop that touched it 6 months. Add driving, temp change, braking, etc, will turn a small blemish of 6months ago into a much larger one now.
    Daily: 2010 VW Jetta Highline
    Erskineville, NSW
    Quote Originally Posted by kam View Post
    Can also flat spot under braking - even with ABS. Or maybe just a crap tyre.
    Mar 2007
    Bridgestone S001. This is my second set as they have some much grip.
    Man In Black (MIB)
