Results 1 to 7 of 7
Thread: Bulb Out Warning light
    Apr 2008
    GOR Victoria
    Lighting system malfunction light has come on and I'm buggered if I can find anything wrong. There are so many little lights all around the cabin of the GTD, very difficult to find a fault.
    Hope all will be ok until next service in a couple of months so that dealer can sort it.
    Nov 2012
    re: Bulb Out Warning light
    Exterior lights?
    Apr 2008
    GOR Victoria
    Checked them and they are all ok.
    Mar 2013
    Brisbane QLD
    LED's installed?....VDUB ..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Apr 2008
    GOR Victoria
    No LED"S. I've crawled around the car including brakelights, and all lights look ok. It's a pain putting up with warning light. Two hours from dealer.
    Nov 2009
    Are you referring to the 'bulb out' error light in the instrumentation? (A small yellow bulb icon.)
    When the car throws a bulb-out warning light, the 'errors/warnings/notices' page in the MFD will be available, and should give you a hint as to which light has blown. Just press the right arrow on your steering wheel to scroll through the MFD pages, till you see the notices page with the info you need.
    Apr 2008
    GOR Victoria
    Thanks AdamD, you're a genius. It told me to check left reversing light, and bingo!
    Now I'll work out how to change it.
