Results 1 to 6 of 6
Thread: Bug barrier for air grills
    Sep 2011
    Has any body made a bug barrier for there air grills in there GOLF or is there something available from VW as down here in South Australia when you drive between towns there are a lot of locust and grass hoppers around and they are not the best to get on your intercooler as they are a bugger to clean of. ?
    Misfit:devils fork::devil fork:
    Jan 2010
    Brisbane - QLD
    Hey mate, I fitted some shade cloth behind the grill when I traveled western Qld a couple of years ago. Keeps the locusts out no prob and easy to hose off when your able to. No cooling issues either.
    Brian
    Current drive:2016 Golf GTI 40 Years in Pure White
    Sep 2011
    Thanks Brian how did you get it behind the bottom grill I have it behind the top grill, but not sure how to get the bottom grill out.
    Misfit.
    Oct 2010
    Perth
    I bought some fly mesh from bunnings, cut it to the required shape and covered the grills from the outside.
    May 2011
    Prahan, Vic
    I'm on a farm and grassseeds blocking radiators is a perennial problem. Small seeds (eg silver grass, vulpia sp.) will go through fly wire.
    I use the grey filter cloth used at the front of domestic air conditioners to keep the seeds out of the front of my Hi Lux and it does a great job - cheap also so change twice/year.
    I tried some on my Octavia RS when the shade temp was 37 and it didn't move the water temp. and increased the oil temp 3C-4C.
    Used between grill and radiator.
    Sep 2011
    Thanks for all the feedback lads, for the moment I have a fly screen behind the top air grill and in-front of the bottom grill till I find out the best way to pull out the bottom grill to put the screen behind.
    Misfit
