Originally Posted by
DOM02R
I've had a few people say to me Brembo, but I think it's just because they're a well known brand and not from any actual first-hand experience. From what I can see, they seem very expensive too, and possibly overkill for daily street driving (not track). If they're the best, then I don't mind paying for it but I don't want to throw money into something I won't use to its full capacity, if you know what I mean.
There's a few options depending how complicated you wish to get.
Simplest will be a pad, rotor, guide & fluid change with maybe a set of braided lines if that floats your boat.
Brake Fluid: Unless you know for certain it's been changed properly in the last 2 years I'd start here. VWs are supposed to use a low viscosity fluid (VW spec 501.14) such as VW OEM brake fluid, ATE SL6, LiquiMoly SL6, Pentosin Dot 4 LV, Textar DOT 4 PRO or Land Rover RRS D3. I think it's a Super Dot 4 fluid with a lower cold viscosity.
Make sure the ABS pump is cycled before bleeding (can use VCDS for this).
Rotors: DBA 4000 series. Plain face for a stealth look or get the slotted. There are other equally good choices. Get hatted rotors if you want to save some weight.
Pads: ATE ceramic (use the matching ATE rotors and you get a great warranty). Ferodo DS2500, Forza or QFM A1RM.
Guides: The rubber guides for the caliper sliders go oval after a few years. OEM rubber guides & pins are cheap (~$30) on eBay or fit a Tyrolsport caliper stiffener kit.
Braided lines: Your choice - Goodridge or HEL?
If you want to go multi-piston you can go with a kit (ask Martin what he's got) or fit a NSBBK (not so big brake kit) using Porsche rear brake calipers on custom mounts.
