Should look fantastic. Like, Man, Wow!
Contact Kevin Rudd re house insulation
OR, make a sandwich, eg, some of that reflective foil under the vinyl? (Just joking)
Seriously, I don't think rust will be a problem. And Canberra is rather far from the sea. But be careful re glue specification. Have you considered maintenance?
Re heat, how do all these cars with skylights make out? Red hot sticky leather upholstery?
Also vinyl will actually add a small layer of heat insulation in winter, although BLACK WILL offset reflective properties of white paint, the inherent thermal resistance of vinyl should compensate. (including white vinyl, vs black, as the heat reflective surface depends on the shiny paint.)
Providing you can leave tops of windows open a little, will make a big difference.
MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
