Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: Bi-Xenon issues GTI6
  1. #61
    Feb 2009
    Quote Originally Posted by Lima
    My S3 does the needle sweep thing at start up. It was cool for the first couple of weeks. Now I don't even notice it.
    You could disable it but I don't mind it, pretty cool.
  2. #62
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Lima View Post
    I took two R's for a test drive, and didn't notice either of them do the needle sweep... but apparently the R's do it... so go figure
  3. #63
    Feb 2009
    The demo R at highway did the needle sweep..
  4. #64
    Feb 2009
    Sydney, Australia
    Oh... I'm sure it did. I'm sure the ones I was in probably did it too. It's just when you turn on the car and that rush of excitement flows through your veins, the last thing I noticed was what the bloody needles were doing
  5. #65
    Jan 2007
    brisbane QLD
    I turned off the xenon DRL for a mate but it still isn't right.
    OFF is off, but AUTO means ON. Leaving home only works in AUTO mode (in mk5s it also works in OFF)
    We can't take it out of two stage unlocking either, the option isn't in the MFD. The VCDS label file isn't developed yet, but I'm sure given time it would make things a lot easier in the future. We enabled the sweeping and it took a few key cycles before it worked, but like most people say here, you'd stop noticing it. It is just about the most pointless feature?
    As for 'coming home', I'll go look up what I did to my mother's Eos which runs the mk6 electronics.
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
  6. #66
    Jan 2007
    brisbane QLD
    this is a halogen equipped Eos (which both my mother and I pointed out the halogens suck after having the bi-xenon in the passat)
    46000A3BFA25186040080080340081244151548851208D605C 8000000000
    change to:
    46000A3BFA25186040080080300081244171548851208D605C8000000000
    I also had a play with DRL on the Eos, I was able to make the DRL function on the fogs instead of low beam, but yes the parkers and tail lights stayed on. Still, if the bi-xenon owners are concerned about burning expensive xenon bits, this could be an (illegal) option.
    Yes the xenon parts should last 5 times longer than halogen, but when they fail, it is not fun. Our passat with at 72000km blew both the bulb and ballast on one side. Thanks to ebay, the repair was only $400 in parts and a few hours of my time, but if you pay VW to do it outside warranty you're looking at approx. $1500 as it's a headlight-out job!
    Still, I'd option it without a doubt
    Main Dub:
    1956 Type 1
