Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Bi-xenon issues
    May 2012
    Sydney NSW
    Quote Originally Posted by Missy63 View Post
    Hi
    Polo GTI 12.5 bi xenons seem to have a dark area where beams overlap - sort of a "v" shape - causing some problems on country roads at night. Anyone having similar issues? This is my first experience of bi xenons so not sure if it's a problem or just how they work.
    Thanks
    Yeah, got the same 'problem' with my Passat's bi-xenons . . . with high-beams there seems to be a 'dark' zone right in front of you in the distance where your eyes naturally go to when travelling at highway speeds. With normal high beams the second beam fills this space, but with bi-xenons one beam is all you get. On low beams it is OK for me.
    They light up everywhere else beautifully but leave a dark patch right in front of you in the distance . . . annoying.
    When I get to the first service (unless I get annoyed enough beforehand to do something about it) I will have them point the lights a little inwards so that you get bright spot overlap in the far distance on high beam - you get enough side spread that a couple of degrees inwards will not make a difference to the sides.
    edit/update: did a long night drive recently . . . think the buggers at the factory did not alight the lights properly as I have a very bright spot about 20 degrees to the right (and a dark spot right in front of the car on high beam!) - will have to adjust them and see if that fixes my problem!
    MY12.5 B7 Passat Wagon : : TDI Highline : : Icelandic Grey : : black leather interior
    sports pack | sat-nav | panoramic glass roof | adaptive cruise control | driver/lane assist | bi-xenons/LEDs | RVC plus | auto-park | auto tailgate | tow-bar | mud-flaps | sill-protection | wood trim - ||| - Lakin plate mounts | tinted | Opti-Coat | LED reverse lights | bright white driving lights + turn lights (LEDs were too 'dim')
    Jun 2012
    Central West, NSW
    My issue is when using low beam - on high beam I have no problem. As I live in the country and share my roads with a variety of wildlife I think I'll have to get it adjusted before the first service.
    Mar 2009
    Melb
    there is a certain algorithm to the bi-xenons working.
    First there is the self test on start up where they dip and then level up.
    turning lights work at speeds 0 to 18 kmh.
    works that way on my car.
    Tig 162 R-Line; Audi TT
    Mar 2008
    Canning Vale, WA
    Quote Originally Posted by mr gee View Post
    I'm sure it they work at higher speeds
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Jun 2011
    Adelaide, South Australia
    The lights only turn above around 20km/h. Below that and when stopped, they point straight.
    MY12 Mk6 5 Door GTI | Candy White | Manual
    www.forcegt.com - for car nuts
    Apr 2011
    North Side, ACT
    Quote Originally Posted by XTC838 View Post
    R u sure about this?
    I think they do turn below 20 kmph & when stopped as well - will test again tonight!
    Cheers,
    GTI BY & MY 12.5 - 5 Door
    DSG, Carbon Steel, Bi-xenon, 18inch Detroit, ACC, Sunroof, RVC, Leather, Dynaudio & Window tint. GOT IT
    Jun 2011
    Quote Originally Posted by SChan View Post
    Cheers,
    Positive they only turn above 20km/h
    Mar 2009
    Melb
    Further to this discussion, I found the parameters in the Self Study program 335
    http://www.volkspage.net/technik/ssp/ssp/SSP_335.pdf
    Apr 2011
    North Side, ACT
    Nice read.
    Thanks mr gee
