Results 1 to 4 of 4
Thread: Head unit turns on/off after 20 mins driving
    Oct 2010
    Rockdale, NSW
    Hi all, I'm experiencing the following issue with my head unit.
    After about 20 mins driving the head unit starts turning itself on/off constantly for five minutes. There is also a clicking noise from the relay below steering wheel which marries up with the head unit turning on/off. After about five minutes all returns to normal. The head unit also stays on sometimes when i remove the keys from the ignition plus when starting car I have to manually turn head unit on.
    No other issues occur with the above. I have 105,000 km on the clock. Methinks the head unit is stuffed? Any one have any advice on this matter? Appreciate any help in advance.
    Mar 2013
    Brisbane QLD
    Sounds like you have a golf 5. Golf 6 or eos....if you do them ignitiin switch faulty. Quite common....VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Yep i think it will be the ignition switch - we bought a Mk6 GTI 2nd hand earlier this year and the head unit was switching itself on and off every few minutes. I did a scan with VCDS and had 5 faults all relating to the ignition switch.
    Bought a new switch from ECS Tuning for $50 odd dollars and replaced it - problem fixed immediately. Mind you, replacing the switch entails removal of the steering wheel, airbag and trim around the steering column. The switch itself is a right bugger to get out without specialist tools.
    Here is a copy of the errors my car had. Check your to see if they are the same/similar.
    Below are the errors:
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000532
    Shop #: WSC 01357 011 00200
    VCID: 78F5F6390BC86A9
    Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    5 Faults Found:
    00576 - Terminal 15
    012 - Electrical Fault in Circuit - Intermittent
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
    Ross Tech info:
    00576 - Ross-Tech Wiki
    Part Number Info:
    Vagcom Ross-Tech Codes Ignition Switch Repair - TDIClub Forums
    ECS Tuning Part:
    Ignition Switch
    Oct 2010
    Rockdale, NSW
    Thanks VDUB & Lukas_R for your detailed response. VDUB I have a MK 6.
    I shall buy a new ignition switch and give it a burl
    Many thanks
