-- - SECT 48
Affixing number plate
48. Affixing number plate
(1) The registered operator of a vehicle must ensure each number plate issued
by the Corporation for the vehicle is permanently affixed to the vehicle so
that, when the vehicle is on level ground-
(a) the number plate is at all times in an upright position parallel to
the vehicle's axles; and
(b) the number plate is at all times not more than 1×3 metres above ground
level; and
(c) for a motor cycle, the centre of the number plate is at all times at
least 30 centimetres above ground level; and
(d) the number or letters, or both, on the number plate are clearly
visible from a distance of 20 metres from the number plate at any
point within the space produced by a horizontal arc of 90 degrees and
a vertical arc of 45 degrees, as indicated by the shaded areas in
figures 5 and 6; and
(e) any cover on the number plate-
(i) is clear, clean, untinted and flat over its entire surface; and
(ii) has no reflective or other characteristics that would prevent the
successful operation of a device approved for use under a law relating
to the detection of traffic offences; and
(f) for a motor vehicle other than a motor cycle, one number plate is
affixed to the front of the vehicle and another to its rear; and
(g) for a motor cycle or trailer, the number plate is affixed to the rear
of the motor cycle or trailer.
(2) The requirements in subregulations (1)(a) to (d) do not apply to a number
plate for a vehicle if-
(a) due to the construction of the vehicle it is not practicable to comply
with the requirements; and
(b) the number plate is affixed in a way that complies as far as
practicable with the requirements.
(3) If a vehicle is fitted with a bicycle carrier, the number plate required
under subregulation (1)(f) to be fitted to the rear of the vehicle may instead
be securely affixed to the bicycle carrier.
