Page 23 of 72 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 711
Thread: Best number plate / plate holder style
  1. #221
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Prodigy View Post
    Shame there are no pre-drilled holes anywhere, some accurate measurements are going to have to be taken then, especially for the back..
    Nah - the back is fine - it's hardly changed from the GTI or even the previous models. It's the front bumper that is the issue with the MK6 Golfs, ESPECIALLY if you wish to mount the plate directly to the bumper without the use of the VW plate holder. moonblade87's is the first photos I've seen of the Lakin plate holder for direct mounting, and although still not an idea situation, it looks better than the previous attempt which went onto the existing plate holder (it looked too bulky and clumsy.
    The Golf R's front bumper is different again, and the mounting holes are different too! So that's the big concern.
  2. #222
    Jul 2010
    Perth, WA
    Quote Originally Posted by coreying View Post
    Yeah it's slightly different from the GTi - That's why Phil's going to get the measurements for the R from the VW dealership in Launceston ... For some reason there aren't many R's in TAS at the moment ;o)
    I'll post when he gets back to me ... It will probably be this time next week as I'm away for the week from tomorrow!!
  3. #223
    Dec 2009
    Looking good on the white GTI. Can't tell from my phone, but would I be able to do this seeing as I still have the plugs from the original plastic holder, but not the pins that clipped it the holder on? ie, does this new flat black metal plate have it's own plugs/screws that simply use the existing holes.
    2019 BMW M3 CS
  4. #224
    Feb 2009
    Sydney, Australia
    moonblade87's photo shows a screw in the "flat black metal plate", so I assume it's either screwing into the original plugs, holes, or has it's own plugs which the screws fit into
  5. #225
    Nov 2009
    Quote Originally Posted by elisiX View Post
    Correct - I believe Philip has supplied screws with the bracket that fit into the original holes, but if you order a plate, Philip will happily fabricate and supply whatever you decide looks best for you. Here are some alternate suggestions he's made to me:
    Quote Originally Posted by Philip
    Having the [original lug size] information gives us more possibilities. I have in stock here some 10mm black nylon screw grommets which come with black nylon flat head screws. These are thin enough that I could machine the face of the front bracket to recess the screw head to sit flush. In this way, our bracket could be mounted directly to the car using the existing holes, while allowing a totally secure fitting, at the same time doing away with the overly heavy look.
    There is another alternative... we can supply the bracket with small countersunk holes and provide black Phillips headed self-tapping screws which would screw directly into the existing plugs (the one that hold the standard plastic adaptor on) once the centre pins have been removed.
    elisiX, if you're thinking about it, I'd suggest you shoot Philip an email - he's really helpful and can make lots of suggestions for what suits your tastes best. I can't recommend him highly enough.
  6. #226
    Dec 2009
    Thanks for the comments guys. Really helpful. Will have to get onto Phillip.
    2019 BMW M3 CS
  7. #227
    ok here are the pics you guys asked for.
    Let me know if you guys need me to take more photos. =D
  8. #228
    Feb 2009
    Sydney, Australia
    Thanks for that - it looks good.
    So does the plate bracket against the front bumper, or is there some nylon standoffs behind it? I'm just wondering whether it will start collecting dirt and leaves behind it, or whether there is enough space for them to simply slide through.
  9. #229
    Nov 2009
    Quote Originally Posted by moonblade87 View Post
    Many thanks moonblade87! The result looks very good IMO, and I reckon I'll get the same plate made up for my GTI.
  10. #230
    No problem =)
    Glad I could help.
    Corey, the bracket has some nylon standoffs behind it. Oh and i forgot to mention the venture shield was a complete bumper kit including top of the rear bumper, door cusps and door sills. And the installation went around the brackets, not underneath them (so no protection behind the brackets).
